Found these in a set. No idea what is being made here. Toothpicks?
baja (Dec 8, 2020), bigtrev8xl (Dec 8, 2020), KustomsbyKent (Dec 7, 2020), rlm98253 (Dec 7, 2020), WorkerB (Dec 12, 2020)
My guess is they're making parts for furniture. Tapered spindle legs with cross-drilled holes for braces/stool foot rests, etc. Can't explain the octagonal (?) bit and the ring but I can envision furniture designs that might make use of same.
Jon (Dec 7, 2020), KustomsbyKent (Dec 7, 2020), Moby Duck (Dec 13, 2020), rlm98253 (Dec 7, 2020)
It's curious that on the wide paint brush handle routing machine they are doing a conventional cut (cutter running against the rotation fo the tool).
You can even see the handle splinter on the outfeed end of one of the cuts.
The two-sided copy-shaper shown in the last video is climb-cutting both sides (one spindle is running in left hand rotation).
Having been a woodworking engineer for 20 years, I notice these things...
Charles Waugh
www.charleswaugh.com
