Results 1 to 4 of 4
Thread: How To Resurface a Brake Disc Rotor for a Toyota Tacoma Pickup
    Supporting Member Catfish's Avatar
    Oct 2013
    Mariposa, California
    Catfish's Tools
    Cool How To Resurface a Brake Disc Rotor for a Toyota Tacoma Pickup
    #BrakeResurfaceing#DiscBrake#BrakeRepair
    I resurface the Brake disc for my sons Toyota Tacoma Pickup using my 16 x 60 metal lathe. I show how to set them up in a metal lathe to maintain concentric true with the axis of rotation. This works out great, and very much a home shop job for the DIY.
    Video Link:
    Dovetail Cutter and Scribe Info. Email me at RRINTHEHSOP@GMAIL.COM
    Please Subscribe: https://www.youtube.com/user/Catfish6945/
    Tool Links: Metric Tap & Die Set : https://amzn.to/2U8tThK
    SAE Tap & Die Set: https://amzn.to/2UTV2sY
    Follow me on Instagram: https://instagram.com/rrintheshop/
    Visit me on You Tube for many tool making videos.
    Link: https://www.youtube.com/user/Catfish6945
  2. The Following 3 Users Say Thank You to Catfish For This Useful Post:
    Jon (Aug 8, 2019), mwmkravchenko (Aug 8, 2019), Seedtick (Aug 8, 2019)
    Sep 2018
    nova_robotics's Tools
    I've done this before but I really have no foundation for whether or not what I did is any good. What's the acceptable tolerance for thickness? Any idiot (i.e. me) can throw a set of rotors on a lathe and resurface them, but how out of plane can those two faces be? I've heard 2 thou is acceptable runout, but that seems like a lot.
    I've turned 1000's of rotors on a brake lathe and more than I care to admit to on an engine lathe but can't recall ever turning the rotor around to turn the other side.
    I found the easiest way to turn a rotor in an engine lathe is to have a pair of massively oversized boring bars or a homemade one that you can insert a cutting tool in from either side mount the rotor from the hub so the disk is furthest way from the chuck dial the mating face that attaches to the spindle hub or better yet leave the rotor mounted to the car hub make an arbor to fit the hub then turn the disk using the bar just like you would on a brake lathe. But then again I have used brake lathes like an engine lathe as well Anco lathes are massive with bulk and stable as granite even the light weight variable speed Van Normal brake lathes are good for turning lots of things if you don't have a conventional metal lathe
    Oct 2013
    Catfish's Tools
    Min. Thickness is usually marked on the rotor. Run out/Parallel tolerance I do not know. But within 0.001" is what I shoot for, seem to work fine for me.
