This is how I turned a very cheap palm router into a pretty useful toolpost grinder for my lathe.
I was surprised at just how good the results were from grinding with this tool.
If you do make one please make a safety guard.
Cheers
EnginePaul (Apr 17, 2023), Jon (Apr 17, 2023), olderdan (Apr 18, 2023), WmRMeyers (Apr 18, 2023), xraybiker (Apr 19, 2023)
Thanks Cazual Haze! We've added your Tool Post Grinder to our Grinding category,
as well as to your builder page: Cazual Haze's Homemade Tools. Your receipt:
Nicely made attachment
When cyl grinding you need to rotate the work in the opposite direction to the wheel, this stops the loose grit and debris (and there always is some) from being crushed back into the work. You will get a better finish that way. I dont grind in the lathe but instead I use a CBN tipped tool which will cut 65 Rockwell hardened tool steel for better than ground finish.
drivermark (Apr 6, 2024)
Congratulations Cazual Haze - your Tool Post Grinder is the Homemade Tool of the Week!
This is a very well thought-out build (part one is here), and it was built using some older homemade tools, including a tailstock die holder and a diamond wheel dresser.
Acid Vat by Frank S
Keyway Cutter Attachment by LMMasterMariner
Track Guide Plates by thehomeengineer
Cylinder Square by PaulsGarageProjects
Drilling and Countersinking Bit by mr_modify1
Micrometer Cheek Pieces by Occasional machinist
Explosives Cargo Box by Frank S
Marking Gauge by Make Things
Carbide Insert Holder by Improvised DIY
Work Table Brake by Frank S
Cargo Box Mount by Frank S
Mini Hand Grinder by My MiniCrafts
Cazual Haze - we've added your tool entry to our All Homemade Tool of the Week winners post. And, you'll now notice the wrench-on-pedestal award in the awards showcase in your postbit, visible beneath your username:
And, you'll be receiving a $100 online gift card, in your choice of Amazon (US-only), PayPal, or bitcoin. Please PM me your current email address and award choice and I'll get it sent over right away.
Nice work!
Wow thank you stunned people think the grinder is a worthy contender.
casual.haze@gmail.com
