Thread: How To Make a Simple Doweling Jig - DIY
    Supporting Member diyfixman's Avatar
    Jan 2019
    diyfixman's Tools
    Dowel joinery is a great alternative to drilling pocket holes. They are ideal for making cabinet face frames and other small woodworking projects. Dowel holes can be marked by manually measuring and lining up the pieces to be attached, or using a dowel jig to help. Store bought dowel jigs can do the job in a variety of ways and are a more accurate time saver over manual measuring. You can use couple pieces of scrap wood and bushings to make your own dowel jig that is cheap and accurate. A drill press with a forstner bit will help make the holes straight and clean and the bushings are available at any hardware store.
    Amazing Videos and DIY Guides, Explanations, Tips, Tricks and Much More...
    Facebook Page | YouTube channel
  2. #2
    Thanks diyfixman! We've added your Dowel Jig to our Jigs category,
    as well as to your builder page: diyfixman's Homemade Tools. Your receipt:
  3. The Following User Says Thank You to DIYer For This Useful Post:
    diyfixman (Apr 23, 2020)
