How high tensile chain is made.
Chain making GIFs
Making heavy duty chain - GIF
Chain making GIFs
baja (Jan 4, 2019), Beserkleyboy (Jan 3, 2019), blkadder (Jan 3, 2019), neilbourjaily (Jan 3, 2019), NortonDommi (Jan 9, 2019), oldpastit (Jan 6, 2019), PJs (Jan 4, 2019), ranald (Jan 5, 2019), Seedtick (Jan 3, 2019), Tonyg (Jan 4, 2019), volodar (Jan 4, 2019)
Phil has made an excellent point but not sure if that answers your question fully. chain is not like flat bar ,obviously, which quickly bends due to its own weight as does pipe & even rhs.
lifting chain is often used incorrectly for other purposes & can suffer from forces other than those for lifting. Used for towing for example can stretch the links. dragging through a fire can change the properties without noticable external damage. Nicks, like a knot, also affect it safe working load. when it comes down to the point the very old addage "a chain is only as strong as it's weakest link" is correct. I believe that w.l.l & s.w.l takr into consideration various angles from vertical to almost level & the pressures therein & on. A good rule of thumb if damage like nicks, & stretches are evident then they must not be more than 10% of the link involved or the chain is not safe to use. This is also true of chain used for other purposes (beside lifting) eg: securing a piece of plant using "dog(s)".
