Results 1 to 5 of 5
Thread: How gas pumps know when to turn themselves off - video
  2. The Following 10 Users Say Thank You to Altair For This Useful Post:
    asterix (Dec 20, 2022), BuffaloJohn (Dec 19, 2022), emu roo (Sep 16, 2024), EnginePaul (Dec 19, 2022), Moby Duck (Dec 24, 2022), mtsintra (Dec 19, 2022), mwmkravchenko (Dec 20, 2022), nova_robotics (Dec 19, 2022), odd one (Dec 24, 2022), thehomeengineer (Dec 19, 2022)
    Lake Tahoe
    IntheGroove's Tools
    These do not work using a 12 volt pump...
    Jan 2016
    Moby Duck's Tools
    Quote Originally Posted by IntheGroove View Post
    It’s not the fact that it is 12 volts that is the problem. The design relies on the flow of fuel in the Venturi, creating the suck to make it all work. What you need is a pump of any voltage that delivers the correct flow of fuel through the Venturi. If the pump specs are correct, perhaps the amperage available from your 12 volt source is not enough to run the pump at the desired output.
    Lake Tahoe
    IntheGroove's Tools
    What brand of 12 volt pump do you use that has the flow required to work the nozzle?
    What IntheGroove, is referring to are the fuel transfer pumps normally mounted on bulk storage tanks either in the bed of a pickup or on a bulk farm fuel tank. Thes pumps are either on or they are off the nozzle does not shut off the pump it merely stops the flow the pump is still running at pressure, but since the valve is closed no fuel comes out. There is no need for those multi valved pressure and flow regulating handles in fact since the pumps are constant pressure constant flow unlike a station pump where the pump is a variable displacement with flow requirements that can go all the way down to near zero flow, these handles do not work very well at all.
  7. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    IntheGroove (Dec 25, 2022), Moby Duck (Dec 25, 2022)
