Thread: Horizontal bead roller setup
    Once I needed to make some turn tables to be mounted flush to the floor for moving trolleys around that ran in a guide track so the direction could be changed
    to do this I also needed to make a seal to protect the inner workings of the turn tables the bearings and posilocks
    So I made a set up to mount my bead roller on the turn table.
    the turn table is 1320 mm in diameter
    the seal is a 10 mm O ring
  2. The Following 3 Users Say Thank You to Frank S For This Useful Post:
    Paul Jones (Aug 10, 2018), PJs (Aug 10, 2018), Seedtick (Aug 9, 2018)
    Thanks Frank S! We've added your Horizontal Bead Roller Setup to our Bead Rollers category,
    New plans added on 12/18/2024: Click here for 2,637 plans for homemade tools.
