Page 3 of 3 FirstFirst 1 2 3
Results 21 to 26 of 26
Thread: Horizontal Bandsaw "mods"
  1. #21
    Supporting Member pfredX1's Avatar
    Sep 2016
    Delaware
    pfredX1's Tools
    I've done 4 mods to my 4x6 band saw. Two I'd do again in a heartbeat. The other two sounded like a good idea at the time, but I could have done something better with my time. As I have not used either very much. The two winners are my speed jack screw mod, and my replacement blade stop. I put up an article on Instructables about my speed jack screw. Here's a link to that https://www.instructables.com/id/4x6...ise-Jackscrew/ The other mod I did I use the most. When I use the saw in the vertical orientation I don't bother with that flimsy sheet metal table that came with it. That thing isn't worth the time it takes to mount it. I used to always just cut stuff on the stop that came on the saw. But that thing is tiny, so it is not much of a table really. I made a bigger one, and just leave it on the saw so it is ready to go all the time. It is a huge improvement over using the original piece. Here's a picture of my enlarged saw stop that I use as a vertical cutting table on my saw http://i.imgur.com/aCbW2wX.jpg
    I modeled it in cardboard first, blah blah. People that can fab should be able to figure out how to make one for themselves. I also lost the original stock stop so I made myself another one when I needed it one day. Not really a mod, more like a duh http://i.imgur.com/ZJOD8Db.jpg I eventually found the original but I do like mine a bit better.
    The mods I did that didn't pay off were I tapped a hole in the base for a toe clamp like the guy is showing here, and I made a lip on the drop end to put a clamp there to hold pieces. A guy on the net made a persuasive case for it, so I did it, but I just don't use it. It was a real pain in the ass to make too. So skip that http://i.imgur.com/VxfY7wD.jpg
  2. The Following User Says Thank You to pfredX1 For This Useful Post:
    Paul Jones (Oct 22, 2017)
  3. #22
    dwbachor's Avatar
    May 2017
    Sweet! Never thought of using mill clamps. Will be doing this in the future.
    Supporting Member will52100's Avatar
    Oct 2015
    Bassfield, MS
    will52100's Tools
    Never thought of mill clamps, will have to give it a try. One of the things I have been setting up a rip fence and using my vertical bandsaw for is cutting mosaic tiles for mosaic damascus. Basically bringing the end grain of a pattern welded bar to the surface by cutting 3/4" tiles at a 45 deg. angle and flipping and forge welding. The more accurate the cuts and even the tiles, the better. Don't know why I never thought of mill clamps for this, should work great. Thanks.
    courtneyknives.net
  5. #24
    PS: Mill clamps.
    Milling clamps depend on leverage to work effectively. Two things assure this.
    1] toe of clamp should bear on the part at lowest possible angle, not flat. Setup of step blocks is easy, 1 tooth higher than part, especially when block[s] right next to part. I do it first without studs, clamps or anything in the way.
    2] Strongest clamp force at lowest torque with stud closest to clamp toe.
  6. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
    Paul Jones (Apr 1, 2018), PJs (Apr 4, 2018)
  7. #25
    WinDancerKnives's Avatar
    Jul 2016
    Three great ideas 'shared' in a single post. Thanks to all!
    Dave
  8. #26
    Sep 2014
    I made some few changes to my saw
