Page 3 of 3 FirstFirst 1 2 3
Results 21 to 27 of 27
Thread: Homemade scissor style hood hinges
  1. #21
    19richie66's Avatar
    Jan 2018
    I joined this forum to to say thank you for this design and making the pattern available for others to use. This will work perfect for my garden tractor I am building. The factory hood hinge set up is useless and this will allow me to tilt the hood up and out without hitting the grille. I am interested in how you would put the gas struts on it and what size. Thank you again, Richie
  2. The Following 2 Users Say Thank You to 19richie66 For This Useful Post:
    blkadder (May 21, 2018), Jon (Jan 12, 2018)
  3. #22
    Jan 2018
    Is there any reason other than style/looks, that the bars are curved? couldn't this be done with straight bars? thanks
    Dec 2020
    Mark
    I found your scissor hinge on a google search. I'm attempting to duplicate it to lift the hatch on my sailboat, but I'm running into a problem. On a car hood there's very little or no overlap. On a boat hatch there's an overlap of probably an inch. I've been able pretty much duplicate your design, but I can't figure out how to get the lift before the swing. Was wondering if you can aid me with your CAD magic :-)
    Thank you
    Lowell ... Southern California
  5. #24
    Jan 2016
    Check out this Linkage page for some simple explanations.
    https://technologystudent.com/cams/link1.htm
    Jeedub57
  6. #25
    May 2012
    Byron, Michigan
    astroracer's Tools
    Hi Lowell,
    I can try! I will need some dimensions from you though. Length of the hatch, the depth of the flange and how much clearance there is between the flange and the hatch opening. Once I have those I think I can reconfigure the pivot points to get what you need.
    Mark
  7. #26
    Dec 2020
    Mark
    Thank you for your prompt response. I'll get measurements in the next couple days.
    Lowell
  8. #27
    Dec 2020
    Jeedub57 ... cool link to watch but can I build my own stuff on the site?
