Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
Thread: Homemade scissor style hood hinges
    May 2012
    Byron, Michigan
    astroracer's Tools
    I am building a Pro Touring style Astro Van. One of the styling changes I am planning is extending the hood to cover the cowl all the way back to the windshield. There is also a full length cowl type scoop in the works. Stretching the edge of the hood back to the windshield will prevent it from opening in the original direction. These are some hood hinges I designed to let the hood open towards the front like a Corvette.
    This is a mark-up I did so you can see the in car relationship. This is with the hood closed.
    And this is with the hood open. Cutting and notching the radiator support will provide plenty of strength to carry the hinges.
    The hood will open a full 100 degrees and I plan to have quick release fasteners to allow quick removal. I will also work some gas cylinders in there to help control the hood while closing.
    Mark
  2. The Following 10 Users Say Thank You to astroracer For This Useful Post:
    19richie66 (Jan 11, 2018), baja (Feb 21, 2020), blkadder (Mar 7, 2017), EnginePaul (Feb 21, 2020), Jon (Feb 16, 2016), kbalch (Feb 17, 2016), mr herb (Feb 21, 2020), Paul Jones (Feb 17, 2016), sossol (May 21, 2018), Tuomas (Jul 11, 2016)
    Supporting Member blkadder's Avatar
    May 2012
    Florida, USA
    An amazing looking hinge to be sure. Might you have any drawings with measurements? I would love to scale one down for a friends go kart body.
    Ron
    ...Semper Fidelis...
    May 2012
    Byron, Michigan
    astroracer's Tools
    Quote Originally Posted by blkadder View Post
    These were designed in CAD and then sent straight to a laser cutter. Let me see what I can do to get you a drawing.
    As you look at the hinge the short pieces are the same piece and the pivot pieces are the same piece so all you need is two patterns.
    Mark
    Quote Originally Posted by astroracer View Post
    Mark
    Hi, is there any way you could get me a cad file or drawing? I want to build these for my Chevelle. Thanks, Mark
    May 2012
    Byron, Michigan
    astroracer's Tools
    Hmmm, let me see if I can find a file. A few years ago and a number of computer upgrades... I may have them on a B/U drive somewhere but I am not sure. I don't remember finding anything for blkadder. I may have to remodel them. Would a .DXF file work for you? Or an IGES?
    Mark
    May 2012
    Byron, Michigan
    astroracer's Tools
    I looked thru two B/U drives this evening and found nothing... I will have to remodel them. Sorry, I will get them done but it may take a bit.
    Mark
  8. #7
    Actually, if you could just give me some basic dimensions and hole centers, i'll be good to go. I am going to build them by hand.
    I want to build some to use on a fiberglass "pin on" hood for my Chevelle. They will work perfect.
    Much appreciated.
  9. #8
    May 2012
    Byron, Michigan
    astroracer's Tools
    That'll work. I'll try to get something marked up this weekend.
    Mark
  10. #9
    Dec 2017
    Interested as well
    Mark
    Interested as well, looking for this same style hood hinge for my 34 Ford. Rod shop wants $180. Figure i can make them for about $20 and a couple hours.
  11. #10
    Astroracer did you experience any wind flutter getting under the hood trying to lift the leading edge I have seen some factory hinges that would do this without some catch lock under the hood to keep it down
