Material is 45cm long piece of 54kg/m rr-track.
baja (Dec 11, 2020), bojones (Jan 28, 2021), CedarSlayer (Feb 13, 2021), clydeman (Dec 10, 2020), Jon (Dec 10, 2020), mklotz (Dec 10, 2020), rossbotics (Dec 11, 2020), that_other_guy (Jan 31, 2021), thehomeengineer (Mar 8, 2021), Tonyg (Dec 11, 2020), trevor_60_r (Dec 18, 2020), volodar (Dec 10, 2020), yogicath (Dec 11, 2020)
Gorgeous work, Tuomas. The finish is fine enough to use the anvil for making jewelry; no marks left in the gold by the anvil. You're a real artist with that grinder too.
It was mentioned in first pinned comment.
Tools and abrasives used:
Metabo WE 2200-230 230mm angle grinder with 2mm thick 3M cubitron 2 cut off wheels. For making the cuts. Making all cuts took about 3 wheels.
Metabo WEV 11-125 Quick 125mm 1100W angle grinder with 3M cubitron fibre disc. For rough shaping and smoothening. Used two 36grit wheels.
METABO W 750-125 125mm 750W angle grinder with 3M Roloc pad.
Used: 60,80 and 120 grit Roloc cubitron papers. Two pcs each.
Brown, red and blue 3M Scotch brite finishing pads. One pcs each.
Anvil was made during two days.
that_other_guy (Jan 31, 2021), yogicath (Dec 11, 2020)
Thanks Tuomas! We've added your Anvil to our Anvils category,
Comments are always welcome
Doug
