Results 1 to 6 of 6
Thread: Homemade Rim Set || heavy duty || Let's Learn Something
    Supporting Member Let'sLearnSomething's Avatar
    Nov 2018
    Let'sLearnSomething's Tools
    Let's Learn Something:
    This is my homemade heavy duty rim set using square bar and this is use in side wheel of tricycle usually in Philippines.
    Quotes: (Eleanor Roosevelt)
    "Great minds discuss ideas, average minds discuss events, small minds discuss people. "
    Don't forget to SUBSCRIBE.
  2. The Following 5 Users Say Thank You to Let'sLearnSomething For This Useful Post:
    IAMSatisfied (Jan 27, 2019), jimfols (Jan 25, 2019), PJs (Jan 26, 2019), toma (Jan 26, 2019), wolfpaak (Jan 26, 2019)
    Nov 2018
    guys this is my new homemade thank you
  4. The Following User Says Thank You to Let'sLearnSomething For This Useful Post:
    Supporting Member IAMSatisfied's Avatar
    Apr 2017
    The desolate ranch country of Northeastern corner of New Mexico, USA
    IAMSatisfied's Tools
    Very excellent wheel truing skills yo have there! Thank you for sharing.
    Question: Where is your welding ground clamp attached? The reason I ask is because if you are running your ground circuit through your wheel bearings, arcing in the bearings can degrade them.
  6. The Following User Says Thank You to IAMSatisfied For This Useful Post:
    olderdan (Jan 28, 2019)
    Nov 2018
    Yes bro i put the ground into the stand and the bearing now is quite hard to rotate and i will change the bearing again for better rotation. Thanks bro
    olderdan's Tools
    Good point, a friend messed up his lathe headstock bearings by grounding on the bed while welding a rotating part.
    Nov 2018
    thanks bro but i don't have lathe machine
