Results 11 to 20 of 29
Thread: Homemade Belt Sander
    That's some piece of work, Vernon! I have to applaud your dedication in building it.
  2. The Following User Says Thank You to DIYer For This Useful Post:
    Vernon (Nov 25, 2014)
  3. #12
    Feb 2013
    South of Brazil.
    Hotz's Tools
    Excellent work ...
    Sorry my mistakes in english.
  4. The Following User Says Thank You to Hotz For This Useful Post:
  5. #13
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    HEllo,
    well done, that's really professional grade !
    Question, why did you prefer the vertical position for the belt ?
    Can you change the orientation ?
    christophe
    Cheers !
    Christophe
    Facebook : La Belle Note
  6. The Following User Says Thank You to Christophe Mineau For This Useful Post:
  7. #14
    Supporting Member Vernon's Avatar
    Nov 2014
    Ocala, Florida
    Vernon's Tools
    Thank You DIYer
  8. #15
    Nov 2014
    Ocala, Florida
    Vernon's Tools
    Quote Originally Posted by Christophe Mineau View Post
    HEllo,
    christophe
    I like to use the wheel to do heavy grinding or shaping. The vertical section I like to do finish work I run a fine belt to leave a nice finish. I didn't build it to lay down but sure I could build one that would. Thank you Vernon
  9. #16
    Nov 2014
    Ocala, Florida
    Vernon's Tools
    I want to share some of how my homemade belt sander was built. I will start off showing the table tilt section The CNC mill was very handy to build the "circular interpolation" or (Curved Slot). I started off with a pcs 7/8" Thick by 5" wide and 12" long. I used a torch to cut it out and than ground it to shape followed by some sanding. Picture 1 shows the two parts of the trunnion Hinge The knob section was split down the center to build the stationary section of the hinge. I than did all the work to the large piece and than I removed a section so it would slip around the knob. (Picture 6) shows the finish piece. The reason a Trunnion Hinge is used is so what ever angle the table is set at the table maintains the same distance from the table to the paper. I will show more section soon so check in on the post to see more.
    Attached Images Attached Images
  10. #17
    Wow, such attention to detail!
  11. The Following User Says Thank You to DIYer For This Useful Post:
  12. #18
    Nov 2014
    Ocala, Florida
    Vernon's Tools
    OK building the table section. First I started off with cold finish plate rounding off the corners. Than I used a horizon mill called Cincinnati 40 40 to cut the grove for the slide. Than I turned the plate over and used a Bridgeport milling Machine, laying the head over to cut back the edge so the table can tilt. Added 3 blind hole to hook the table to the tilting arm showed in last post. More picture to come so keep watching.
  13. #19
    Feb 2013
    South of Brazil.
    Hotz's Tools
    Very good, many hours of work
  14. #20
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Hi Vernon,
    An awesome project, as well as an interesting and useful homemade tool! Your Belt Sander is the 'Tool of the Week'!
    You'll be receiving one of our official HomemadeTools.net T-shirts:
    Let me know (via PM) your size, color choice, and mailing address. We'll get the shirt in the mail to you directly.
    Congrats!
    Ken
  15. The Following User Says Thank You to kbalch For This Useful Post:
    Vernon (Nov 26, 2014)
