Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 11 to 20 of 47
Thread: Home built universal grinder
    Aug 2021
    Cape Town SA
    albertq's Tools
    Thank you. Indeed when I grind a part and the micrometer shows you are well within 0.01mm it's a great feeling.
  2. #12
    Aug 2021
    Cape Town SA
    albertq's Tools
    Hi Jon,
    I've added some sub-assembly Http files to my post, thus allowing non Fusion 360 viewers to study the assembly's in more detail and can also remove parts for more clarity.
    If they have Fusion 360 CAD, these files can be opened in Fusion with all associated details.
  3. The Following 2 Users Say Thank You to albertq For This Useful Post:
    Jon (Nov 25, 2023), Saltfever (Nov 25, 2023)
  4. #13
    Apr 2012
    NorCal
    Saltfever's Tools
    Albert: Once again I want to thank you for your beautiful presentation and generous sharing of your IP. The http files are easier to orbit than an actual F-360 model! My question is about design intent. Is the timing belt drive on x axis as precise as the ball screw on Y? Or does it even matter since you have fine feed on both axises? What was your thinking in choosing one over the other?
    All the best, -Kirk
  5. #14
    Thanks albertq! We've added your Universal Grinder to our Grinding category,
    as well as to your builder page: albertq's Homemade Tools. Your receipt:
  6. #15
    Aug 2021
    Cape Town SA
    albertq's Tools
    All the best, -Kirk
    Hi Saltfever, my rational for the ball screw on the y axis, was because it is critical for cylindrical grinding, as you are feeding on radius like a lathe, whereas on the x-axis it is straight liner feed and my longitudinal tolerance's are mostly larger than my diametric tolerances. The x-axis belt although wide and steel reinforced still has some stretch, so not as accurate as the y-axis. Likewise I have a ball screw on the Z-axis for fine surface grinding height control.
  7. The Following 2 Users Say Thank You to albertq For This Useful Post:
    mwmkravchenko (Dec 6, 2023), Saltfever (Nov 27, 2023)
  8. #16
    Aug 2021
    Cape Town SA
    albertq's Tools
    Quote Originally Posted by stillldoinit View Post
    Beautiful build and pride shown in craftsmanship. Looks like it took more than a couple weekends to put this together. Your build rivals anything in the marketplace,WELLDONE!
    Thanks Stilldoinit, it did take some time but enjoyed the challenge, after all this is my hobby.
  9. The Following User Says Thank You to albertq For This Useful Post:
    ozylee (Nov 28, 2023)
  10. #17
    Sep 2020
    Australia
    Hi Albertq,
    I have been involved with machine tools in building and repair (mainly CNC) machines for over 45 years and very impressed with your quality machinery and drawing details.
    If you could send the .dxf files I would be most appreciated.
    I have often thought about building a universal grinder but yours is the next level up.
    It would be a project that I would love to attempt.
    What I see on your parts photo I may have many of the bearings and linear way in my workshop already that I have collected over the years.
    Just waiting for the right project to attempt.
    Cheers
    Ozylee
  11. #18
    Apr 2012
    NorCal
    Saltfever's Tools
    Albert: Could you post a picture of your control panel? How did you make it; anodize, engrave, silkscreen, etc? Thank you.
  12. #19
    Aug 2021
    Cape Town SA
    albertq's Tools
    I drew up the panel face on CAD then had a decal made. In hindsight I should have sprayed a couple of clear coats over it before wiring it all up, as the printing wears off fairly easily if you rub it.
    I made both the panel and box cabinet housing the drivers & power supply, with hinges to make working in them more comfortable.
    Home built universal grinder-hinged-electrical-housings-easy-access-2-.jpgHome built universal grinder-hinged-electrical-housings-easy-access-1-.jpgHome built universal grinder-img_5778.jpg
    Attached Thumbnails Attached Thumbnails Home built universal grinder-img_5778.jpg
  13. The Following 2 Users Say Thank You to albertq For This Useful Post:
    mwmkravchenko (Dec 6, 2023), Saltfever (Nov 28, 2023)
  14. #20
    Albert,
    Considering the effort that you put into this you must be really annoyed with the mis-spelling in the 4th axis column. Many years ago I had a batch of Tee shirts made with a spelling mistake and I hated it.
    On some projects I have made face panels by simply laser printing on to adhesive backed paper and sprayed a couple of coats of clear as you mentioned. Recently I have used a laser engraver but that tends to limit the colours. You need light coloured lettering on a dark coloured background. I paint the panel white to start with and then followed by black. The black absorbs the laser light and burns off, but the white reflects the light and stays intact.
