Thank you. Indeed when I grind a part and the micrometer shows you are well within 0.01mm it's a great feeling.
Albert: Once again I want to thank you for your beautiful presentation and generous sharing of your IP. The http files are easier to orbit than an actual F-360 model! My question is about design intent. Is the timing belt drive on x axis as precise as the ball screw on Y? Or does it even matter since you have fine feed on both axises? What was your thinking in choosing one over the other?
All the best, -Kirk
Thanks albertq! We've added your Universal Grinder to our Grinding category,
as well as to your builder page: albertq's Homemade Tools. Your receipt:
New plans added on 11/22: Click here for 2,593 plans for homemade tools.
Hi Saltfever, my rational for the ball screw on the y axis, was because it is critical for cylindrical grinding, as you are feeding on radius like a lathe, whereas on the x-axis it is straight liner feed and my longitudinal tolerance's are mostly larger than my diametric tolerances. The x-axis belt although wide and steel reinforced still has some stretch, so not as accurate as the y-axis. Likewise I have a ball screw on the Z-axis for fine surface grinding height control.
mwmkravchenko (Dec 6, 2023), Saltfever (Nov 27, 2023)
ozylee (Nov 28, 2023)
Hi Albertq,
I have been involved with machine tools in building and repair (mainly CNC) machines for over 45 years and very impressed with your quality machinery and drawing details.
If you could send the .dxf files I would be most appreciated.
I have often thought about building a universal grinder but yours is the next level up.
It would be a project that I would love to attempt.
What I see on your parts photo I may have many of the bearings and linear way in my workshop already that I have collected over the years.
Just waiting for the right project to attempt.
Cheers
Ozylee
I drew up the panel face on CAD then had a decal made. In hindsight I should have sprayed a couple of clear coats over it before wiring it all up, as the printing wears off fairly easily if you rub it.
I made both the panel and box cabinet housing the drivers & power supply, with hinges to make working in them more comfortable.
mwmkravchenko (Dec 6, 2023), Saltfever (Nov 28, 2023)
Albert,
Considering the effort that you put into this you must be really annoyed with the mis-spelling in the 4th axis column. Many years ago I had a batch of Tee shirts made with a spelling mistake and I hated it.
On some projects I have made face panels by simply laser printing on to adhesive backed paper and sprayed a couple of coats of clear as you mentioned. Recently I have used a laser engraver but that tends to limit the colours. You need light coloured lettering on a dark coloured background. I paint the panel white to start with and then followed by black. The black absorbs the laser light and burns off, but the white reflects the light and stays intact.
