Results 1 to 9 of 9
Thread: high speed drill.
    big o's Avatar
    Prescott . Arizona
    big o's Tools
    high speed drill.
    This drill was made to complement my Unimat DB200 lathe.It has a 4"stroke and the capacity can be increased or decreased by moving the motor up or down using a threaded rod on the back post.The motor is rated to over 20,000 rpm's on 36Volts.I run it on an 18Volt wall mount transformer ,it has good torque.RPM's are controlled thru a potentiometer .Chuck quill return is thru a spring taken from a 8mm camera.Base is a quartz cut-out off a counter top.Unit is bolted with "T"nuts drilled thru base.Wiring is hidden in holes drilled thru quartz base.
    high speed drill.-brushless-motor-2.jpghigh speed drill.-brushless-motor-3.jpghigh speed drill.-brushless-motor-drill.jpg
  2. The Following 10 Users Say Thank You to big o For This Useful Post:
    DIYSwede (Dec 26, 2020), Home-PC (Dec 25, 2020), Jon (Jan 4, 2019), PJs (Jan 5, 2019), rossbotics (Jan 5, 2019), Scotsman Hosie (Jan 8, 2019), Seedtick (Jan 4, 2019), threesixesinarow (Jan 11, 2019), tonyfoale (Jan 5, 2019), Tonyg (Mar 19, 2019)
    Aug 2016
    wizard69's Tools
    I posted in the other thread but I have to say I really like this little drill press. Put some linear scales on the DY table and you an do arrays of holes with ease. Think printed circuit boards and the like here. In any event it looks to be one handy machine.
    12L14's Avatar
    Aug 2017
    12L14's Tools
    Those twenty quids proxon knockoffs are great - except you can't use them manually...
    ps. I heard you can get them in US for mere 20 bucks(shipping, tax etc. included)
    Thanks big o! We've added your High Speed Drill to our Drilling and Drill Presses category,
    as well as to your builder page: big o's Homemade Tools. Your receipt:
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Nice job Big O, very clean build. I like the idea of using the quartz counter top also...stable, easy to clean and doen't absorb oil and chips. Thanks for sharing your build.
    PJ
    Mark Twain
    tell us a bit more about your spindle motor
    thanks
    animal
  8. #7
    Aug 2020
    Yes, the motor. Where does it come from? I sure would like one of these.
    I see you are in Prescott, well I'm just down the road in Mesa.
  9. #8
    big o's Avatar
    Prescott . Arizona
    big o's Tools
    Motor is a 775 12v- 36v Dc. With a B10 chuck. Bought from Ali Express, for less than $20 bucks. Walmart has them,also Ebay. You will also need a controller to
    regulate speed. These motors are popular with the RC. car builders. I run it on a 18v. transformer, scrounged off a back-vibrator. Excellent when useing small high-
    speed drills.
    big o.
  10. #9
    Aug 2020
    Thanks Big O
    Quote Originally Posted by big o View Post
    speed drills.
    big o.
    Very helpfull. Nice little press I think.
