Quote:
View southeast of weldment assembly floor in structures shop, building 57; the floor is fabricated of cast iron and features a grillwork of 1 1/2 square holes which are used as sockets for gripping positioning or lock down pins; a lock down pin is shown left and below the center of the photograph; the vertical section of the pin is placed into a hole in the cast steel floor while the angles section of the pin rests on the piece under construction; the pin is hammered into the hole and spring tension in the pin holds the work piece in position. - Naval Base Philadelphia-Philadelphia Naval Shipyard, Structure Shop, League Island, Philadelphia, Philadelphia County, PA
Fullsize image:
Quote:
Overall interior view of structures shop (11 shop) located on west side of building 57 - looking north; the south end of the structures shop was devoted to welding heavy plate foundations and ship components; the floor is fabricated of case steel and features a grillwork of 1 1/2 fabricated holes which are used as sockets for gripping position pins. - Naval Base Philadelphia-Philadelphia Naval Shipyard, Structure Shop, League Island, Philadelphia, Philadelphia County, PA
Fullsize image:
