Page 85 of 101 FirstFirst ... 35 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 LastLast
Results 841 to 850 of 1007
Thread: High-quality black-and-white photographs of large old machines and tools
  1. #841
    Mar 2020
    So, after all, a mule is not stubborn and can works. From the common phrase ' stubborn as a mule'.
  2. #842
    Supporting Member schuylergrace's Avatar
    Sep 2020
    Mesa, Arizona
    I was imagining single-point threading that rod at the top.
    For topical application, only. Not to be taken internally or used in com-
    bination with other drugs or alcohol, except as directed by your shaman.
    Do not operate heavy equipment, unless you actually know how to.
  3. #843
    hemmjo's Tools
    Quote Originally Posted by IntheGroove View Post
    If any tool needed eyes painted on it that's it...
    HA, I just got that!!! Sometimes it takes me a while, depending on the day!!
    High-quality black-and-white photographs of large old machines and tools-gator-shear.png
  4. The Following 2 Users Say Thank You to hemmjo For This Useful Post:
    IntheGroove (Nov 1, 2022), Jon (Nov 2, 2022)
  5. #844
    Twenty mule team drawn combine. Walla Walla County, WA. 1941.
    Fullsize image: https://diqn32j8nouaz.cloudfront.net...6_fullsize.jpg
    re post 836, the mule team and combine.
    With no clue what's going on here, examining photo revealed some details. The hitch is just pulling the machine, and it's power plant to run the combine itself, plus what ever tasks of surprisingly large crew, including filling the sacks piled on left side.
    Then wikipedia......The modern combine harvester, or simply combine, is a versatile machine designed to efficiently harvest a variety of grain crops. The name derives from its combining four separate harvesting operations—reaping, threshing, gathering, and winnowing— to a single process. Among the crops harvested with a combine are wheat, rice, oats, rye, barley, corn (maize), sorghum, soybeans, flax (linseed), sunflowers and rapeseed. The separated straw, left lying on the field, comprises the stems and any remaining leaves of the crop with limited nutrients left in it: the straw is then either chopped, spread on the field and plowed back in or baled for bedding and limited-feed for livestock.
    Combine harvesters are one of the most economically important labor-saving inventions, significantly reducing the fraction of the population engaged in agriculture.
    https://en.wikipedia.org/wiki/Combine_harvester Article may have been written by an Englishman, as I Americanized spelling of ploughed and labour-saving.
    This post demonstrated likelihood many are quite ignorant of goings-on 24/7/365 to keep us fed. Though a huge probability existed the mules were bred here in Missouri.
  6. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    mr mikey (Nov 1, 2022)
  7. #845
    Imagine shearing 7" cold steel!
    Ralph
    Recalling what we've seen of MESTA equipment, could be their compact model........
    Compared to shears that descend guided at each end, this is a variety known (perhaps colloquially) as an alligator/ aka high angle shear. Both use the inclined blade angle just like scissors do. The blade clearance on the MESTA was probably not good for sheetmetal, but smaller bench shears do it easily.
    Never sheared 7" but can report a 6' wide 'gator nipped hot rolled stock for welding coupons 1-1/2" and 2" thick, hardly making a sound. 25-30 minutes or so, would supply a big pile of them. Then handful of guys would eat 50 pound boxes of electrodes running multi pass weld samples.
    Neither one a bill I'd like to foot.
  8. #846
    Quote Originally Posted by schuylergrace View Post
    Must be referring to the tie-rod connecting the upper frame. While your doing that, I'm ordering 2 cuts of hex bar to single point the nuts. Definite opportunity to bore pitch and maximum diameter references.
  9. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    schuylergrace (Nov 1, 2022)
  10. #847
    Supporting Member mr mikey's Avatar
    May 2022
    Michigan
    mr mikey's Tools
    You know you're getting old when you remember that black and white commercial for Twenty Mule Team Borax cleaner. Good stuff.
  11. #848
    hemmjo's Tools
    Quote Originally Posted by mr mikey View Post
    I used to have a model of the Twenty Mule Team Borax team and wagons. Not sure what happened to it.
  12. #849
    Sep 2012
    Hinchinbrook QLD
    Dave, from Engels Coach Shop, (Youtube) built a full size 20 mule team borax wagon, (x2) and a water cart from scratch.
    The link is a brief rundown of the process but there is also a full series of videos on each step. Its a fantastic channel. I love his stuff.
  13. The Following 6 Users Say Thank You to 12bolts For This Useful Post:
    Bullet500 (Nov 3, 2022), Corm (Nov 6, 2022), hemmjo (Nov 2, 2022), Jon (Nov 2, 2022), lavern s (Nov 2, 2022), mr mikey (Nov 2, 2022)
  14. #850
    May 2022
    Michigan
    mr mikey's Tools
    Wow, the craftsmanship is awesome. Thank you for posting.
  15. The Following User Says Thank You to mr mikey For This Useful Post:
    allenz (Nov 7, 2022)
There are currently 5 users browsing this thread. (0 members and 5 guests)
