Page 82 of 101 FirstFirst ... 32 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 LastLast
Results 811 to 820 of 1007
Thread: High-quality black-and-white photographs of large old machines and tools
  1. #811
    What appears to be cutter heads, the inclined 'toolposts' is a very precise yet easy adjustment in simultaneous centerline and diameter correction for setup, independent of the 'cross slide'.
  2. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    mr mikey (Aug 8, 2022)
  3. #812
    The name for the tooth pattern sometimes called a double helical but most often called a Herringbone. As I mentioned in another thread about the ability to transmit more torque with a helical than a straight cut gear the Herringbone design takes that to a far new level not only in the ability of handling increased torque the design does 2 more things it virtually eliminates lateral thrust plus can offer near zero backlash.
    Here is a small pair of gear I have made out of aluminum
    High-quality black-and-white photographs of large old machines and tools-img_20220808_141119xc.jpg
    High-quality black-and-white photographs of large old machines and tools-img_20220808_141129xc.jpg
    High-quality black-and-white photographs of large old machines and tools-img_20220808_141142xc.jpg
    Here are a few examples of larger gear sets even right angle
    High-quality black-and-white photographs of large old machines and tools-800px-engrenages_-_85.488_-.jpg
    High-quality black-and-white photographs of large old machines and tools-r-2-.jpg
    Due largely to the double angle cut of the gears which in turn alters the stress angle in the body of both gears a higher ratio between pinion and bull can be obtained since there is also more tooth contact and more teeth in contact than a straight cut spur gear
    Ralphxyz (Aug 9, 2022), Scotsman Hosie (Oct 1, 2022)
  5. #813
    Rikk's Avatar
    Nov 2018
    Rikk's Tools
    Mesta Machine Company double helical gear planer. West Homestead, PA. 1905/1925.
    I would love to see that wonderful machine run.
  6. The Following User Says Thank You to Rikk For This Useful Post:
    mr mikey (Aug 9, 2022)
  7. #814
    Quote Originally Posted by Rikk View Post
    As would we all, anything of MESTA Machine Co.
    With us short guys in front..........
  8. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    Rikk (Aug 9, 2022)
  9. #815
    Supporting Member mr mikey's Avatar
    May 2022
    Michigan
    mr mikey's Tools
    You got my vote. I'd like to see that aslo. In my early years I helped set up machines but nothing that big. Cool stuff. Mr Mikey.
  10. The Following User Says Thank You to mr mikey For This Useful Post:
    Rikk (Aug 9, 2022)
  11. #816
    10,000 ton forging press at Carnegie Steel Company's Homestead Steel Works. 1893-1895.
    Fullsize image: https://diqn32j8nouaz.cloudfront.net...s_fullsize.jpg
  12. The Following 4 Users Say Thank You to Jon For This Useful Post:
    Inflight (Aug 15, 2022), jimfols (Aug 22, 2022), nova_robotics (Aug 15, 2022), Scotsman Hosie (Oct 1, 2022)
  13. #817
    Sep 2012
    Hinchinbrook QLD
    100,000 tons?
    I think maybe an extra zero slipped in there!
  14. #818
    Quote Originally Posted by 12bolts View Post
    100,000 tons?
    Good call; my error. All fixed now.
  15. #819
    48-inch mill at the Homestead Steel Works. Homestead, PA. 1954.
    Fullsize image: https://diqn32j8nouaz.cloudfront.net...l_fullsize.jpg
  16. The Following 2 Users Say Thank You to Jon For This Useful Post:
    nova_robotics (Aug 22, 2022), Toolmaker51 (Aug 22, 2022)
  17. #820
    When a supervisors office is on casters, likely he's many processes to oversee.
    He knows it's a large plant, when that office also has lifting eyes to hoist by bridge crane.
    Of so many pics Jon has presented, this is first I recall depicting duckboards.
    Have made a couple over the years, best surface for prolonged standing, and minimizing chips underfoot. Lifted occasionally, chips are right there, ready to scoop and dispose.
    But end-grain wood bricks still first choice.
  18. The Following User Says Thank You to Toolmaker51 For This Useful Post:
