Page 79 of 101 FirstFirst ... 29 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 LastLast
Results 781 to 790 of 1007
Thread: High-quality black-and-white photographs of large old machines and tools
  1. #781
    Supporting Member mr mikey's Avatar
    May 2022
    Michigan
    mr mikey's Tools
    don't tell Osha lol.
  2. #782
    Mesta Machine Company rope drive wheel. Homestead, PA. 1905/1925.
    Fullsize image: https://diqn32j8nouaz.cloudfront.net...l_fullsize.jpg
  3. The Following 2 Users Say Thank You to Jon For This Useful Post:
    jimfols (Jul 24, 2022), mr mikey (Jul 24, 2022)
  4. #783
    Sep 2015
    Ontario Calif USA
    782
    I never knew that.
    High-quality black-and-white photographs of large old machines and tools-rope-drive.jpg
    Multiple rope drives driving lineshafts on each factory floor
    Jim
  5. #784
    Apr 2016
    yup I saw that somewhere I visited. them smart fellers, split the power to any where in the factory.up down over change ratio for something I was amazed whay all they had done with it many many years ago. the down side is...when the power head stops it all stops. but there are addvantages to just one power unit, like put it outa the way.heat,noise etc.
  6. #785
    May 2022
    Michigan
    mr mikey's Tools
    Good stuff. When I was a kid I liked going to Greenfield Village in Dearborn Mi. and always spent the most time in the machine shop, all belt driven. I think I need another trip there. Mr Mikey.
  7. #786
    Apr 2016
    when my wife retires ,I... we hope to travel the country and see lots of stuff like that. thats if there is still a country to see.
  8. #787
    hemmjo's Tools
    What am I missing?
    I am looking at that massive "wheel" which appears to be cast in one piece. The hub is bored and spilt. They appear to be cutting the keyway. There appears to be 4 bolts to clamp the hub to the shaft by squeezing the 2 halves of the hub together. Each half of the hub is attached to the outer rim rim of the wheel by 3 stout spokes.
    Something has to move when they squeeze that hub down onto the shaft. Does it flex that massive wheel?
    High-quality black-and-white photographs of large old machines and tools-massive-hub.png
  9. #788
    May 2022
    Michigan
    mr mikey's Tools
    Hello, I'm just guessing, maybe the shaft and bore clearance is slightly press fit then when the clamping bolts are torqued as runout is measured its in spec.? also since belts are running at a slow rpm its not considered an issue.? Mr Mikey.
  10. #789
    If you want to see one (all right, a much smaller one) in action...
  11. The Following 2 Users Say Thank You to mklotz For This Useful Post:
    jimfols (Jul 25, 2022), Ralphxyz (Jul 25, 2022)
  12. #790
    What am I missing?
    Exactly right, but only the hub, there aren't spokes across the center.
    The cutter head has a tapered arrangement with set screws to control depth. Boring a split hub is common, the gap is shimmed and clamped, the same torque on fasteners secures on shaft at installation.
    It looks like a boring mill, so must be using the quill Z axis as a broach, like a lathe chucked part, cutter driven by carriage. Possibly, that era had a mechanism to run the quill in and out without rotating spindle?
    However, can't imagine a spindle within a square quill, I believe the machine is a shaper.
    An alternative would Z the table; but this is a floor machine, not table type. Floor machines are considered 'portable', they secure the column at the part, the 'floor' actually is a giant Tee slotted plate. Dialing in a part, isn't a couple handles like a Bridgeport.
    Along with all that, the bore could have been done in a vertical lathe. The casting has been turned, those grooves ain't cast, an concentricity included. Biggest I've heard of was 33'; if man in picture is 5'5'', that's an 16' to 18' sheave.
    But, here's a 42' Industrial History: Big Machine Tools
    https://newatlas.com/the-citroen-che...3868/?amp=true
    Last edited by Toolmaker51; Jul 25, 2022 at 02:25 PM. Reason: extra helping of links
  13. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    hemmjo (Jul 25, 2022)
