Page 75 of 101 FirstFirst ... 25 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 ... LastLast
Results 741 to 750 of 1007
Thread: High-quality black-and-white photographs of large old machines and tools
  1. #741
    Sep 2012
    Hinchinbrook QLD
    Beer o'clock. **** always happens at beer o'clock
  2. #742
    Long before OSHA made tools "safe" for idiots. Tools, especially rotating tools, are dangerous and should be viewed that way.
    Apr 2016
    I wonder just when osha will start cutting off fingers so the morons wont poke their own eye out..... like labels on car batterys.do not drink... hears a good one, my new gm roadster(AKA 2 seater) says to put baby in the rear .......ok so I locked my babys in the trunk....it has a safety pull if they need out.... again you can not fix stupid. hears a reall good one, pontaic solstice, saturn sky,daewoo x2 and opal speedster had recall child seat airbag sensors... the fix that the NHTSA told gm they could do was a short strip of duct tape and try to tape the sensor togeather....witch lasted 20 times being used, then the owner is on the hook for over $1000 us. it seems the NHTSA got a pay off from GM to do this patchwork. if it cant be made to work with dict tape then and only then they will put the new upgraded tottaly different sensor in the vehicle...it's made in china not mexico. the ductape is supposed to hold togeather the oh so thin copper strip ribbon...that cant be fixed. again you cant fix stupid or scammers or payoff schemes.
  4. The Following 2 Users Say Thank You to marksbug For This Useful Post:
    baja (May 22, 2022), Toolmaker51 (May 16, 2022)
  5. #744
    Machining a steel wheel. Wheel and Axle division of Homestead Steel Works. April, 1962.
    Fullsize image: https://diqn32j8nouaz.cloudfront.net...g_fullsize.jpg
  6. The Following 2 Users Say Thank You to Jon For This Useful Post:
    jimfols (May 22, 2022), nova_robotics (May 23, 2022)
  7. #745
    44-inch blooming mill engine room. Jones & Laughlin Steel Corporation. Aliquippa, Pennsylvania. January, 1952.
    Fullsize image: https://diqn32j8nouaz.cloudfront.net...m_fullsize.jpg
  8. The Following 3 Users Say Thank You to Jon For This Useful Post:
    jimfols (May 29, 2022), nova_robotics (May 30, 2022), Toolmaker51 (May 29, 2022)
  9. #746
    bruce.desertrat's Tools
    The scale of these things just always amazes me...those nuts in the foreground are are bigger than those workers' heads...
  10. #747
    Sep 2015
    Ontario Calif USA
    Quote Originally Posted by bruce.desertrat View Post
    I was thinking the same thing when I saw these wrenches.
    High-quality black-and-white photographs of large old machines and tools-wrenches-large.jpg
    Jim
  11. #748
    And then impossible not imagining the machine that threaded them. Or the mill rolling the initial hexagonal bar.
  12. #749
    Lake Tahoe
    IntheGroove's Tools
    Jon, find us the big nut maker...
  13. #750
    Making large diameter threads is not much of a task. I've made both internal and external 18" diameter threads 4 TPI on a 16" gap bed lathe using a homemade 20 inch diameter face plate instead of a chuck to take advantage of more of the gap Obviously not hex stock. One of the strangest threads for me at least was when I made a 3 start 8 TPI thread full length on a 4inch diameter bar and the nuts to go with it.
    For those who don't know doing a 3 start *TPI thread you only make the cuts as deep as if you were doing a 24TPI but you must be precisely 120° between starts
