Results 1 to 4 of 4
Thread: Helicopter rotor blades shattered by strong winds - GIF
  2. The Following 6 Users Say Thank You to Altair For This Useful Post:
    nova_robotics (Jun 29, 2023), piper184 (Jun 29, 2023), Ralphxyz (Jun 29, 2023), rlm98253 (Jun 29, 2023), Scotty1 (Jul 1, 2023), that_other_guy (Jul 1, 2023)
    Supporting Member Fluffle-Valve's Avatar
    Oct 2015
    Duston, Northampton, UK
    So who would have thought this? The blades are made to wizz around at a high rate, but a cross wind just snaps them apart.
    I have a 1972 Land Rover Series III Truck Cab/Pick-Up and a 1962 Land Rover Series 2a Carawagon Camper.
  4. The Following User Says Thank You to Fluffle-Valve For This Useful Post:
    nova_robotics (Jul 3, 2023)
    Apr 2014
    Gadgeteer's Tools
    Quote Originally Posted by Fluffle-Valve View Post
    It appears it was more than just a crosswind... suspect the blade encountered vertical/lifting wind when it rotated over the edge of the deck. The copter was just too close to the edge, and was susceptible to increased wind speed, caused by the deflection at the sides of the vessel. Same effect when semis get blown over by wind rising out of a ditch slope along a highway... happens frequently during windy months, along I-90, close to town.
    Sep 2018
    nova_robotics's Tools
    Spinning is what prevents them from snapping. Being composite (carbon fibre?) the things are probably brittle like spaghetti noodles, so much so that a bit of wind can cause them to buckle when stationary. Put a few tons of centrifugal force on each blade and keep them in tension, and all of a sudden they can tolerate 200-400 mph wind loads easily, plus the entire weight of a fully loaded helicopter.
    Like pre-stressing concrete. Loading up concrete with additional force to keep it in compression actually makes it far, far stronger.
