Heightening steel posts under a structure.
1850s raising of Chicago buildings - image
Raising a heavy post without machines - GIF
Raising a large tank - GIF
Raising a wind turbine - GIFs
New plans added on 09/04: Click here for 2,441 plans for homemade tools.
mr mikey (Jul 10, 2024), nova_robotics (Jul 10, 2024)
You do, all of those darker support posts you see with hoses connected to them are long st5roke hyd. cylinders doing the lifting these will be anchored tot eh slab and if you watch the right side of the screen, you can see much larger columns also telescoping. Those are lifting and stabilizing as well. Judging from the men moving about, the scale of the building appears to being altered from about 10or 11 ft clearance to 15 or 16 ft
baja (Jul 10, 2024), drivermark (Jul 10, 2024), Floradawg (Jul 10, 2024), hemmjo (Jul 10, 2024), nova_robotics (Jul 10, 2024), that_other_guy (Jul 18, 2024)
