Results 1 to 10 of 13
Thread: Handheld laser welder - GIF
  2. The Following 11 Users Say Thank You to Altair For This Useful Post:
    Andyt (Feb 9, 2020), baja (Feb 7, 2020), high-side (Feb 7, 2020), Jon (Feb 7, 2020), mklotz (Feb 7, 2020), rdarrylb (Feb 6, 2020), redneck (Feb 8, 2020), Rikk (Feb 6, 2020), Seedtick (Feb 6, 2020), Slim-123 (Feb 8, 2020), Texf1 (Feb 7, 2020)
    hemmjo's Tools
    I WANT ONE of those!!
  4. The Following User Says Thank You to hemmjo For This Useful Post:
    Supporting Member JoeVanGeaux's Avatar
    Jun 2018
    Magnolia, TX
    Handheld Laser Welder Specs?
    Nice!!
    What are the specs on that handheld laser welder?
    Supporting Member McDesign's Avatar
    Sep 2016
    McDesign's Tools
    Where's the bead material coming from? Some sort of wire or powdered MiG?
    Quote Originally Posted by McDesign View Post
    The weld bead probably comes from reduction of base metal fusion. A lot of tig welders will make welds without any filler. I do it all the time when welding tubing with an oyx acyt torch
    Nov 2019
    Looks very interesting! Is there more info available on this???
  9. #7
    Sep 2016
    McDesign's Tools
    Sure, I do, too - but there's clearly a raised bead.
  10. #8
    I can't tell that the bead is raised even in the enlarged view it just looks brighter which could give the illusion of being raised
    if there is a filler material as fast as he draws the torch across the material it would have to almost be powdered to vaporize and fuse that fast but I can't see any tell tail dust maybe that is in the smoke though.
    Like someone mentioned more info would be nice
  11. #9
    Dec 2014
    South Dakota
    KustomsbyKent's Tools
    I have seen this type of welder when I was in China. There is not a filler metal being added, it is fusing the base materials together. Because the weld bead is so shiny, it looks raised, but is not. The weld bead is concave, like a fillet, rather than being raised or convex like a conventional filler based weld.
    The ones I saw were in a machine fixture, but operated just like this. Most common use for them was making the channel letters for store logos. The flat of the back was laser cut, and then the perimeters were flat sheet, anywhere from 25mm to 50mm wide, and scored in places so that it could form around the letter or logo shape. Then the laser welder was used to join the back to the perimeter. Typically the inside was filled with some LED elements and then the face was a piece of tinted plex that fit in. Then you had some nice lit up letters or logos to promote your business.
    Here's an example of one... I got to try something very similar myself, pretty cool!
  12. The Following User Says Thank You to KustomsbyKent For This Useful Post:
    Paul Jones (Feb 8, 2020)
  13. #10
    Dec 2017
    baja's Tools
    Quote Originally Posted by KustomsbyKent View Post
    In the 80`s I worked at a small sign shop making channel letters like those (and sign cabinets) but we used paint-lok and spot welded them. Before the days of LED sign lighting so the pattern would go to the neon shop to have neon bent to fit inside. Nothing like this, we traced the pattern on the paint-lok and cut the back out with snips and wrapped the return around it. Good memories.
