Results 1 to 6 of 6
Thread: Hand-cranked torque multiplier lug nut wrench - GIF
  2. The Following 7 Users Say Thank You to Jon For This Useful Post:
    baja (Nov 4, 2019), greyhoundollie (Dec 29, 2019), high-side (Nov 5, 2019), jdurand (Nov 1, 2019), rgsparber (Nov 1, 2019), sak778 (Dec 4, 2021), Seedtick (Nov 1, 2019)
    I know my 3/4 to 1" torque multiplier will put out some scary torque levels when I use a 3 ft long break over bar and apply my full weight to it.
    come bleed or blister something is going to happen.
    baja (Nov 4, 2019), Scotsman Hosie (Nov 4, 2019)
    jdurand's Tools
    I hadn't seen one before, but makes perfect sense.
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    I suspect that inside is a helix that attaches to the socket. As the user turns the crank, a nut moves towards the socket end of the toop and rides down the helix. The pitch of this helix must be large in order to provide the needed mechanical advantage. With lots of grease on the surfaces, it should all work smoothly. Brilliant design!
    Rick
    Rick
  7. The Following User Says Thank You to rgsparber For This Useful Post:
    jdurand's Tools
    I was thinking a planetary gear, but don't know.
  9. The Following 3 Users Say Thank You to jdurand For This Useful Post:
    greyhoundollie (Dec 29, 2019), sak778 (Dec 4, 2021), Scotsman Hosie (Nov 4, 2019)
  10. #6
    Nov 2019
    I’ve used them quite often, cost about 110$ Australian come with 3 sockets and can be a real ball breaker if rotated in the wrong direction on left handed wheel 1”studs , will literally shear them off not a problem! 😣
  11. The Following User Says Thank You to michaelstrong1974 For This Useful Post:
