Thread: Grounding Rod, Stake or Post Driver Tool, DIY
    Supporting Member tsbrownie's Avatar
    Feb 2019
    tsbrownie's Tools
    This tool is used with a hammer drill (wired or cordless) to drive stakes or rods into the ground. I use it primarily for driving electric ground rods. The last one I did was 3 meters long and took less than 3 minutes and did not bend nor mushroom the rod. It was also tight against a wall.
    Materials Used:
    - 1/2" steel pipe cap (soft steel better than cast). Do NOT use galvanized because of the toxic gases / poisoning that can result.
    - Old hammer drill bit or similar
    - Welding stuff
    The pipe cap is there to center the hammer drill over the rod, so any pipe or similar will work.
    WARNING: Welding is dangerous. If you do not know how, learn first or don't do it.
    Driving ground rods and other can be dangerous or fatal. If you don't know, learn first or don't do it.
  2. The Following 4 Users Say Thank You to tsbrownie For This Useful Post:
    Eaglewood (Feb 18, 2019), Redwoods (Feb 18, 2019), Scotsman Hosie (Feb 19, 2019), Sleykin (Feb 19, 2019)
    Thanks tsbrownie! We've added your Stake Driver to our Miscellaneous category,
    as well as to your builder page: tsbrownie's Homemade Tools. Your receipt:
