Results 1 to 4 of 4
Thread: Grinding Rubber Motor Support Rings
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    It turned out that the rubber support rings that fit on my 1964 motor are not that common. I was able to find rings that had the right OD and then grind the ID to fit. This article explains how I did it: http://rick.sparber.org/MSR.pdf
    Rick
    Rick
  2. The Following User Says Thank You to rgsparber For This Useful Post:
    kbalch (Feb 8, 2016)
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Good job with the Dremel grinder that should last you another 25 years.
    Thanks Rick! We've added your Motor Support Rings to our Miscellaneous category, as well as to your builder page: Rick Sparber's Homemade Tools. Your receipt:
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Thanks Paul. It is always satisfying when I can use my shop to make parts that cannot be bought.
    Rick
