Results 1 to 10 of 11
Thread: Grinder improvements (wire wheel bushing/hub)
    Supporting Member craig9's Avatar
    Jul 2019
    Hobart, Tasmania
    craig9's Tools
    Lightbulb Grinder improvements (wire wheel bushing/hub)
    I'd been having trouble with some horrendous runout and vibration on my grinder - which has a wire wheel fitted to it.
    In this video, I make up a hub/bushing from some 6061 aluminium - the design aims for maximal shaft contact, to hold the wire wheel as perpendicular as possible. Then I balance out the wire wheel using some small sheet metal screws. Not a perfect result, but miles better.
    During the balancing operation the bearings of the grinder started failing I do not get that fixed in this video, but it might be the subject of a future one.
    Cheers,
    Craig
  2. The Following 5 Users Say Thank You to craig9 For This Useful Post:
    DIYer (Mar 1, 2020), greyhoundollie (Mar 2, 2020), Jon (Mar 5, 2020), Saltfever (Mar 2, 2020), Scotsman Hosie (Mar 2, 2020)
    Thanks craig9! We've added your Bench Grinder Hub to our Cleaning category,
    as well as to your builder page: craig9's Homemade Tools. Your receipt:
    craig9 (Mar 9, 2020), greyhoundollie (Mar 2, 2020)
    Apr 2012
    NorCal
    Saltfever's Tools
    Not enough weight? Drill the hub you made and add lead into the hole(s). There would be many ways to capture (or secure) the lead.
  6. The Following 3 Users Say Thank You to Saltfever For This Useful Post:
    craig9 (Mar 9, 2020), greyhoundollie (Mar 2, 2020), Okapi (Mar 3, 2020)
    Jyväskylä Finland
    Tuomas's Tools
    But then it would be out of balance when it comes time to change the wheel.
    Mar 2013
    Switzerland
    Okapi's Tools
    A good idea to show us how you solve this problem, just to precise than you do never use flanges flat than yours with a grinding wheel, as a newcomer can have the idea to make such parts for mounting a grinding wheel.
    On your brush, the necessary recess is on the brush and you don't need a recess on the flanges as on others wheels.
  9. The Following User Says Thank You to Okapi For This Useful Post:
  10. #6
    Apr 2012
    NorCal
    Saltfever's Tools
    Assume you plan to balance the wheel every time. Just drill out some lead if needed. Or maybe more weight will have to be added. You could even change the shape of the flange to be thicker at outer edge to facilitate drilling for adding or removing weight. BTW . . . nice idea.
  11. The Following 2 Users Say Thank You to Saltfever For This Useful Post:
    craig9 (Mar 9, 2020), Macca Boy (Mar 3, 2020)
  12. #7
    Sep 2018
    I solved a vibration on a small sanding disc for glue on sandpaper. Used a propeller balancing jig and the found the light side and drilled a hole for smal screws. Then just screwed in small screws until i got it basically vibration free. You could just drill a bunch of evenly spaced holes and then add or subtract to get it balanced.
  13. The Following 2 Users Say Thank You to mbshop For This Useful Post:
    craig9 (Mar 9, 2020), Jon (Mar 4, 2020)
  14. #8
    Jul 2019
    Hobart, Tasmania
    craig9's Tools
    Thanks Saltfever - good idea.
  15. #9
    Jul 2019
    Hobart, Tasmania
    craig9's Tools
    Quote Originally Posted by Okapi View Post
    That's right - this is designed for and fitted to that particular wire wheel. These are not replacements for standard grinder wheel flanges. If I ever want to put a simple grinding wheel back on that end, I would need to either retain the original flanges, or make up some beefier ones which are relieved and which fit the shaft better.
    Thanks, Craig
  16. #10
    Jul 2019
    Hobart, Tasmania
    craig9's Tools
    I like the idea of pre-drilling a lot of holes ahead of time (not least because it also lightens the heavy side). Then using the holes to add screws/weight back is a great idea!
