Results 1 to 1 of 1
Thread: GoPro Hero 5 Protective Lens Replacement
    Supporting Member Downeast Thunder's Avatar
    Dec 2015
    usa
    Downeast Thunder's Tools
    If you should shatter the outer protective lens of your GoPro Hero 5 video camera as I did, you can easily perform a DIY repair in a couple of minutes and for only $20.00
    My new GoPro Hero 5 Black, action video camera had a shattered protective lens. I thought I would have to send the camera out to have it repaired. As it turns out, the owner can easily renew the protective lens, and I found it available for twenty bucks online (Amazon Prime). Within a couple of days, my new lens arrived via UPS.
    I found the existing lens tough to budge and remove, but it finally came off, and the new replacement lens went on with a much easier amount of effort.
    Here's a short video (just over a minute) showing how easy it is to swap out the protective lens without tools:
    Downeast Thunder Creations
    http://www.downeastthunder.com
    Shoestring Shipyard
    http://www.shoestringshipyard.com
    Downeast Thunder Creations Youtube Channel
    https://www.youtube.com/channel/UCUU...pKFwXTYQ57ex3g
  2. The Following User Says Thank You to Downeast Thunder For This Useful Post:
    Seedtick (Jan 17, 2018)
