Results 1 to 7 of 7
Thread: Global Positioning System Arduino Interface Software
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Global Positioning System (GPS) and Global Navigation Satellite System (GNSS) devices are available at a wide range of prices and are fun to use in an Arduino based project. The hitch is that they spew out “NEMA Sentences” which are easy for people to read but tricky for software. I found a few programs online that convert the sentences to a collection of simple variables, but none would run on my Sparkfun Pro Micro. In the end, I found it necessary to code my own set of subroutines.
    https://rick.sparber.org/GNSS_InterfaceSoftware.pdf
    Thanks,
    Rick
    Rick
  2. The Following 9 Users Say Thank You to rgsparber For This Useful Post:
    byates (Apr 16, 2020), clydeman (Dec 1, 2022), DIYer (Apr 14, 2020), FEM2008 (Apr 15, 2020), JoeVanGeaux (Apr 19, 2020), Jon (Apr 17, 2020), lowracer (Apr 16, 2020), nova_robotics (Apr 16, 2020), Seedtick (Apr 15, 2020)
    Thanks rgsparber! We've added your GPS Data Converter to our Electronics category,
    Jul 2019
    Ohio, USA
    Thanks rgsparber. I have saved a copy of your pdf. This will come in handy, If I ever get back to finishing a project I started a couple of years back.
    jdurand's Tools
    Am I correct in assuming whatever Arduinos use for their scripting doesn't have an equivalent to SSCANF() from the C language? Now granted I often roll my own for specialized things so I don't need to load in the whole library, but the STRING.h stuff is awfully handy when it's there.
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    I'm not familiar with SSCANF() but suspect someone has written a version that runs on some Arduinos. The problem I found is that people write such tools and they don't run on my version of Arduino. I figure that by keeping the code simple, it should be portable.
    It certainly was a lot more work than I thought it would be given all of the different failure modes. Yet, it was a fun challenge.
    Rick
    Rick
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Great work Rick, and useful indeed.
    Yes sscanf works fine in Arduino, but as often, on micro devices, firmwares often require to recode things to exactly fit the need.
    Nice to have error management for the robustness.
    I've never had so far the need for GPS application in standalone Arduino projects, what do you do with it ?
    However, I could see the interest for raspberry Pi project, which can communicate and store bulk data.
    It would be certainly portable for raspi I guess .
    Could use it to geolocalize pictures for instance on my raspi based Wilde life camera.
    Thanks for all the work !
    Cheers !
    Christophe
    Facebook : La Belle Note
  8. #7
    jdurand's Tools
    A company I worked for long ago had a GPS module simply to keep the time in sync between units. The communicated via a leased radio channel and had to have accurate clocks for everything to work.
