Thread: Glass stretching machine - GIFs
    Glass stretching machine aka "Satan's taffy maker." Seriously, what are they making though?
    Pouring glass into thin glass strands - GIF and photo
    Molding glass bottles - GIF
    Glassblowing a dragon stem goblet - GIF, video, photo
    PJs (Dec 12, 2018), Seedtick (Dec 11, 2018)
    I'm not certain what they're making here but the process is very familiar to me.
    When I built my perfusion machine in high school, I needed a cannula with a very tiny diameter to attach the rabbit kidney being perfused to the blood supply. I made them myself by drawing out glass tubing much as is being done (at admittedly larger scale) in the GIFs. Once the cannula is formed, the end was heated and a small bulb was blown to act as a stop so that the cannula won't pull out of the artery once it is sutured in place.
    The devices they're making look more like some sort of laboratory sampling glassware. A thin tube leading to a larger diameter reservoir which, in turn, has a thin tube extending from the top. Suction applied to the top tube will cause fluid to draw up the other tube into the reservoir. Once a sufficient sample is in the reservoir, sealing the vacuum tube will hold the sample until it can be transferred to wherever; then releasing the seal dumps the sample.
    I'm probably completely wrong but it's fun to speculate on these things; I view it as treadmill exercise for the analytic mind.
  4. The Following 3 Users Say Thank You to mklotz For This Useful Post:
    Jon (Dec 11, 2018), KustomsbyKent (Dec 11, 2018), PJs (Dec 12, 2018)
