Results 1 to 5 of 5
Thread: Gear extractor
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Gear extractor
    Another tool I needed, it's something to help extracting the gears on my metal lathe gear box.
    They are always difficult to pull up with the hand.
    So I came to this simple design, that can adapt to all the diameters I have :
    But I must admit that my design has a limitation. I tried to extract with it the pulley of my washing machine motor, the one I used for the disk sander, and I had absolutely no success.
    The main bar started bending before the pulley started to move. It kept completely stuck.
    So I had to build the sander with the pulley still on the shaft...
    Actually, even if the main bar of the extractor has a good section, obviously, at the center, where the screw hole is drilled the section is too much reduced, and the bend starts from there.
    It's a light duty extractor.
    Anyway, it's still of great help for my lathe gear box.
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 3 Users Say Thank You to Christophe Mineau For This Useful Post:
    kbalch (Jan 20, 2015), Paul Jones (Jan 20, 2015), Tule (May 31, 2017)
    I wonder Christophe, if a thick piece of angle iron can be used as a substitute for the flat bar to prevent the bending you described. The jaws would have to be slotted accordingly, of course. Still, a pretty clever idea and something I will keep in mind.
    Jul 2014
    France, Brittany !
    Hi, yes , you are certainly right.
    In fact, what I had in mind is the thickness of that piece, in order to have enough depth for the threading.
    I could consider welding some sides pieces to get the corner shape you are saying, in the middle part, and leaving the wings and the slides as they are, and using a longer screw.
    Yes, that's the idea, thanks Mr DIYer !!
    Cheers !
    Christophe
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Christophe! I've added your Gear Extractor to our Lathes category, as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
    That's a much simpler solution, Christophe, rather than rebuilding that already nice (and useful) puller.
