Results 1 to 1 of 1
Thread: Gear cutting on a CNC
    Supporting Member shopandmath's Avatar
    Jun 2019
    Kitchener ON,CA,
    shopandmath's Tools
    Gear cutting on a cnc
    In this video we will basically cut a gear from start to finish
    we will cover how to setup and zero or touch off the gear cutting tool
    By changing three numbers in the program you can cut any number of teeth and number of passes
    and if you change the Y axis you can cut almost any Diameter size of gear
    not bad for only 22 lines of code
    If you would like to see more about sub programming the next video goes more in depth
    Video link
  2. The Following User Says Thank You to shopandmath For This Useful Post:
    nova_robotics (Mar 12, 2021)
