Thread: Gallium in water - GIF
  2. The Following 5 Users Say Thank You to Altair For This Useful Post:
    Andyt (Jan 12, 2020), greyhoundollie (Jan 14, 2020), jimfols (Jan 12, 2020), Rangi (Jan 13, 2020), Seedtick (Jan 11, 2020)
    Supporting Member nhengineer's Avatar
    Aug 2016
    nhengineer's Tools
    I was wondering what Gallium is. Here's what I found out:
    Gallium is a chemical element with the symbol Ga and atomic number 31. Elemental gallium is a soft, silvery blue metal at standard temperature and pressure; however in its liquid state it becomes silvery white. If too much force is applied, the gallium may fracture conchoidally. It is in group 13 of the periodic table, and thus has similarities to the other metals of the group, aluminium, indium, and thallium. Gallium does not occur as a free element in nature, but as gallium(III) compounds in trace amounts in zinc ores and in bauxite.[6] Elemental gallium is a liquid at temperatures greater than 29.76 °C (85.57 °F), above room temperature, but below the normal human body temperature of 37 °C (99 °F). Hence, the metal will melt in a person's hands.
    The melting point of gallium is used as a temperature reference point. Gallium alloys are used in thermometers as a non-toxic and environmentally friendly alternative to mercury, and can withstand higher temperatures than mercury. An even lower melting point of −19 °C (−2 °F), well below the freezing point of water, is claimed for the alloy galinstan (62–⁠95% gallium, 5–⁠22% indium, and 0–⁠16% tin by weight), but that may be the freezing point with the effect of supercooling.
    You're welcome
  4. The Following 3 Users Say Thank You to nhengineer For This Useful Post:
    greyhoundollie (Jan 14, 2020), Rangi (Jan 13, 2020), Wildwilly (Nov 21, 2021)
