Results 1 to 5 of 5
Thread: G33 Spindle Synchronized Motion on LinuxCNC based DIY Lathe
    Supporting Member GBWM's Avatar
    Nov 2021
    GBWM's Tools
    Describing the G33 cycle on LinuxCNC based machines. It allows to synchronize the spindle with 1, 2 or even 3 linear axis. This gives the possiblity to machine threads on bar stock or even drill-like patterns on cones using a CNC lathe. I'm not sure for what purpose could be used the 3rd axis here - maybe you have any idea?
  2. The Following User Says Thank You to GBWM For This Useful Post:
    NortonDommi (Apr 23, 2022)
    Thanks GBWM! We've added your CNC Spindle Synchronized Motion to our CNC category,
    as well as to your builder page: GBWM's Homemade Tools. Your receipt:
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    Bloody awesome. Wish I could understand what you are doing. You could start making log-splitter cones . Easier than setting up a taper turning attachment.
    Nov 2021
    GBWM's Tools
    I was thinking about it. Maybe when I will have some spare time I'll give it a try.
    Aug 2016
    wizard69's Tools
    There are many things that can be turned as "threads on a cone".
    1. screw extractors
    2. buffing wheel arbors.
    3. log splitters.
    4. custom wood screws.
    5. Tapered end mills.(OK maybe to heavy for most lathers).
    6. Marble tracks with a router attachment.
    There are probably a few more I'm missing. In any event great to see you have G33 working. There are not a lot of posts about using LinuxCNC for lathe work so it is good to see people using it here. One day I'd like to have LinuxCNC running on a machine or two, but that is way off in the future.
