Thread: frozen ball valves
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    frozen ball valves
    In areas with high mineral content water, the shut-off valves under the sink and behind the toilet freeze up after a few years. Forcing the handle never ends well. Waiting for a split line and then forcing the valve is much worse.
    New ball valves cost around $10 and I can't argue with replacing frozen valves when they stick. I did one yesterday. But rather than toss the frozen valves, I put it in a glass jar along with about 1 cup of water and 1 cup of vinegar. After 12 hours, the valve moves like new. I'm now soaking my second valve.
    Rick
    Rick
  2. #2
    Vinegar is as useful in the shop as it is in the kitchen.
    The alkaline batteries in my desk clock leaked their guts out. The battery compartment had white "stuff" all over the plastic. So I'm thinking "alkaline" implies there might be a favorable reaction with a mild acid. I dipped a cotton swab in vinegar and, voila, the "stuff" disappeared. A little work on the metal contacts with a Cratex tip in the Dremel and some NiMh rechargeable batteries (which don't seem to ever leak) and the clock is ready for another few years.
  3. The Following User Says Thank You to mklotz For This Useful Post:
    rgsparber (Dec 24, 2023)
    Oct 2019
    Germany
    uv8452's Tools
    To me the main issue is: Don't let the shut-off valves surprise you. Change the inserts, say, every 3 or 4 years. Don't fear to be perceived as 'square': Put a tag on them: Last changed xxx.
