Results 1 to 6 of 6
Thread: A front loading arbor that stays in the machine when changing parts
    Supporting Member Mook's Avatar
    Sep 2023
    Mook's Tools
    Parts with no through hole can be a problem to clamp in the bore without having to remove the fixture from the chuck or vice. This system allows clamping of the part if there is no access to the rear of the fixture. There are 2 links to more information in the description below the video.
  2. The Following 5 Users Say Thank You to Mook For This Useful Post:
    Inner (Oct 9, 2023), Jon (Oct 9, 2023), mwmkravchenko (Oct 9, 2023), nova_robotics (Oct 9, 2023), uv8452 (Oct 9, 2023)
    Sep 2018
    nova_robotics's Tools
    Okay I had to watch this a few times, so correct me if I'm wrong. The o-rings are allowed to relax, and you slide the part over them making a reasonably tight fit. Then when you tighten the nut it compresses the o-rings expanding them into the ID of the part. That's smart.
  4. The Following User Says Thank You to nova_robotics For This Useful Post:
    It is an expanding mandrel much like you would find to expand an exhaust pipe. if you stop the video at the 1,03 you can just see the lines showing the segments. the o rings would be used to draw the segments together when released by the spanner.
    A truly nice set up though. Fast and repeatable
    Sep 2018
    I don't think there are any reliefs in the metal allowing it to expand. I think it's just a sleeve. He's got a couple links in the description of the Youtube video where he has some additional information.
    https://drive.google.com/file/d/1bLt...6F0li-IRw/view
    https://drive.google.com/file/d/1hBh...Ah_NWyclF/view
    So, he is just squeezing the o rings then. Much simpler than an expanding mandrel. In the video the way the light shown on it, it appeared to have reliefs cut into the mandral Thanks
    Thanks Mook! We've added your Front Loading Arbor to our Workholding category,
    as well as to your builder page: Mook's Homemade Tools. Your receipt:
    New plans added on 01/10/2025: Click here for 2,694 plans for homemade tools.
