Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
Thread: Fly cutter - first try
  1. #21
    Jan 2016
    For anyone interested in old school info and techniques, check out Your Old Time Bookstore. They have a large library of books from the old days. They send out e-mails regularly with 75% off discounts. Very good information and very cheap. Ronj.
    Quote Originally Posted by Canobi View Post
    Well, despite my suggestion of inserts, I hope to keep the old "artisan" aspect of engineering going as I have much love and respect for the old school machines, tools and techniques from back in the day.
  2. The Following User Says Thank You to Ronj For This Useful Post:
    PJs (Jul 22, 2018)
  3. #22
    Oct 2012
    ncollar; hand set multiple HSS bit cutters easily when mounted in the spindle. Use gravity and two feeler gauges at a time. Then a sharp bit doesn't bite sliding shim. Sometimes you can get good results with them 'stepped' in Z axis height from cutting plane. Only need a couple thousandths variation, whichever is highest is the 'rougher'. Common to multi-flute cutters, RPM can be reduced and feed rate increased.
    I did not think about what you said. But letting it sink in I could also rotate the fly cutter around to a fixed point and adjust all cutters with the feeler gauge. Almost like tramming the head but the cutters.
    Thank you for your wise intervention.
    Nelson
  4. The Following 2 Users Say Thank You to ncollar For This Useful Post:
    PJs (Nov 7, 2018), Toolmaker51 (Nov 7, 2018)
  5. #23
    About wise intervention, I'm not so sure. Just doing what it takes, that way a boss keeps handing me checks on Fridays IYKWIM.
    There are all kind of small bound notebooks. I plant them all over; so when inspiration strikes, a trick gets discovered, or reminder to purchase so & so, it gets recorded.
  6. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    PJs (Nov 7, 2018)
