Flat bar bender.
Mandrel bender - GIF
Cotter pin bender - GIF
Automatic strip bender and cutter - GIF
Circular bracket bender - GIF
CNC rod bender - GIF
Flat bar bender.
baja (Aug 22, 2023), cagiva (Aug 27, 2023), desbromilow (Aug 27, 2023), Inflight (Aug 26, 2023), jimfols (Aug 21, 2023), johncg (Aug 25, 2023), KustomsbyKent (Aug 22, 2023), mwmkravchenko (Aug 21, 2023), nova_robotics (Aug 21, 2023), piper184 (Aug 22, 2023), Ralphxyz (Aug 25, 2023), rdarrylb (Aug 21, 2023), Toolmaker51 (Aug 27, 2023), yvonf (Aug 22, 2023)
AKA "hard way" forming, being across the width of material. Not really different than common bending or brake work (across thickness). As in the latter, material needs rigid support of the bed and clamp, such as a box & pan brake.
What is important, material runs in a very closely fit slot, to minimize buckling through the thickness, because great disparity of inner and outer radius. Lubrication helps a great deal, especially in unhardened dies. I use gear (transmission, rear axle etc) lube.
I did a post here regarding a die-set for a HF bender, danged if I can find it.
