Results 1 to 10 of 13
Thread: Fixing those cheap Harbor Freight Bar Clamps
    May 2012
    Byron, Michigan
    astroracer's Tools
    How many of you use these cheap bar clamps from HF? I have a bunch of them, even though they are light duty I use them a lot for woodworking projects as they have a decent clamping force but not strong enough to do any damage like a C-clamp or heavier bar clamps.
    After a few years of use the clamps start "popping" the molded hinge pins for the trigger. This renders them useless.
    I just broke two of them while working on my bed project this past weekend. This is what you'll have when you pull out the trigger.
    After pulling one of them apart. The popped hinge pin.
    I had fixed one a while ago that did this and fixed these two in about ten minutes.
    The trigger has a molded hole that just fits a #10 machine screw.
    See following post
  2. The Following 5 Users Say Thank You to astroracer For This Useful Post:
    Andyt (Dec 5, 2019), Doc (Dec 5, 2013), gunsgt1863 (Oct 21, 2017), Hotz (Nov 8, 2014), kbalch (Dec 4, 2013)
    May 2012
    Byron, Michigan
    astroracer's Tools
    Drill through both sides with a 3/16th's drill. Use the molded hinge pins as locators for the drilled hole.
    Re-assemble the clamp with the screw in place of the broken hinge pin and it will be ready to go to work.
    See next post
    May 2012
    Byron, Michigan
    astroracer's Tools
    Both clamps fixed in 10 minutes...
    I may go through and do this to all of them just to save the headache of breaking one during a job... Only takes a minute.
    Mark
  5. The Following 12 Users Say Thank You to astroracer For This Useful Post:
    Andyt (Dec 5, 2019), drivermark (Oct 18, 2017), gunsgt1863 (Mar 26, 2018), Komo (Apr 1, 2018), Moby Duck (Mar 26, 2018), oldcaptainrusty (Oct 18, 2017), olderdan (Oct 17, 2017), Paul Jones (Dec 13, 2014), Tiny (Oct 17, 2017), Tule (Dec 5, 2019), Ultimaest (Mar 27, 2018), will52100 (Mar 26, 2018)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Great idea! Yet another item for my to-do list...
    Ken
    Quote Originally Posted by astroracer View Post
    Mark
    I was thinking exactly that as I was going through you post. Thanks for the tip!
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    Hello astroracer,now that you have modified those clamps, their not so cheep any more! Good for you and anyone else who likes to mod tools that gets better results. :O)
  9. #7
    Great job in saving the clamp from the trash bin astroracer. The quality of import tools nowadays is abysmal.
  10. #8
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    This thread has been moved to the Must Read subforum. Congrats (and thanks) to astroracer for making such a valuable contribution!
  11. #9
    hemmjo's Tools
    Good idea. Perhaps a small piece of steel (maybe brake line) or copper tubing could over the screw and to keep the threads from chewing up the trigger hole over time. Just a thought.
  12. #10
    Feb 2014
    racer-john's Tools
    My thought also.
