Results 1 to 10 of 10
Thread: Fixing Manual Mill Spindle - No Contact Between The Taper of Tool and Spindle
    Supporting Member GBWM's Avatar
    Nov 2021
    GBWM's Tools
    Hello. Recently I've had problems with a cheap manual mill I bought for my workshop. I wasn't able to fit MT4 tools - these didn't want go deep enough so the taper fits properly. Check out how I solved the problem. What do you think of this solution? Maybe it will give someone an idea how to deal with such issue.
  2. The Following 5 Users Say Thank You to GBWM For This Useful Post:
    asterix (Jun 13, 2022), Jon (Jun 10, 2022), lassab999 (Jun 9, 2022), nova_robotics (Jun 12, 2022), tonyfoale (Jun 9, 2022)
    I did something similar to covert an R8 mill spindle to an ISO 30 taper. I rotated the head to half the included angle and bored the spindle using the vertical table/knee feed. It would not work using the quill feed, that would just bore a parallel hole regardless of the angle.
    It is important that the tool edge is set on the centreline, the equivalent of setting tool height on a lathe.
    This method ensures good concentricity, better than removing the spindle and cutting the taper in a lathe where there will always be some runout.
    The same technique can also be used to repair a damaged R8 taper.
  4. The Following 2 Users Say Thank You to tonyfoale For This Useful Post:
    olderdan (Jun 9, 2022), Toolmaker51 (Jun 10, 2022)
    Thanks GBWM! We've added your Mill Spindle Modification to our Milling category,
    as well as to your builder page: GBWM's Homemade Tools. Your receipt:
    Nov 2021
    GBWM's Tools
    That had to be an interesting operation. Do you have any video of the process?
    Quote Originally Posted by GBWM View Post
    No video nor photos and I do not even have that mill now.
    Nov 2021
    GBWM's Tools
    That's unlucky. But thanks for sharing the idea!
  9. #7
    Jun 2018
    Louisiana
    Use WD40 or kerosene when cutting aluminum
  10. #8
    Nov 2021
    GBWM's Tools
    Quote Originally Posted by TrickieDickie View Post
    Sometimes I use WD40. Is kerosense any better than WD40 or the effect is similar?
  11. #9
    TapMagic is great on Aluminium. WD40 also have a dedicated fluid for machining in addition to their traditional (W)ater (D)ispersant 40.
  12. #10
    MasterMaker's Avatar
    Aug 2012
    Would stay away from WD40 for anything with enough cutting-force to create smoke...
    When I started out I used it and fairly frequently I would get these crazy heart-palpitations with my heart beating at a mile-a-minute and so hard I could properly feel it when I put my hand on my chest, stopped using WD40 and it went completely away...............
    So it would appear that once you heat WD40 past it's smoke-point some kind of CNS active compound is created............
