Results 1 to 4 of 4
Thread: Fire escape ladder collapse - GIF
    Andyt (Dec 31, 2019), greyhoundollie (Dec 30, 2019), Seedtick (Jan 4, 2020)
    looks like the connecting bolts between the lower and the upper section had rusted away or someone had removed them. the single stand off was not designed to support vertical loads failing under the weight of 2 men. the ladder appears to have been rusted way beyond being serviceable anyway since many of the rungs broke away once it hit the ground.
    I'm betting at least 1 possibly 2 or 3 broken legs a couple broken arms and more than a few cracked ribs.
    I would be very surprised to hear there were no broken bones or more serious injuries after a fall from that height with the scrap metal landing on top
    Supporting Member Fluffle-Valve's Avatar
    Oct 2015
    Duston, Northampton, UK
    OUCH!
    What fools they are!
    Why did they not use a ladder to start with? The've climbed the pipework to get to the knackered fire escape ladder.
    I have a 1972 Land Rover Series III Truck Cab/Pick-Up and a 1962 Land Rover Series 2a Carawagon Camper.
    Quote Originally Posted by Fluffle-Valve View Post
    OUCH!
    probably been using that fire escape ladder for years to remove the snow from the roof and never thought about it going bad.
