Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
Thread: FILER GUIDE FOR HAND-SAWS
  1. #21
    Supporting Member Mikhandmaker's Avatar
    Apr 2017
    Mikhandmaker's Tools
    Mikhandmaker
    I agree, 100% this is what HMT.net is all about.
    Identify a task, your design's the solution others can produce.
    Thanks for your support!!
  2. #22
    Supporting Member natie123's Avatar
    Sep 2017
    Eastern Cape, RSA
    natie123's Tools
    FILER GUIDE FOR HAND SAWS
    Thank you Mikhandmaker for a very detailed and informative post. I learned more from your high quality video than just how to make and use the filer guide.
  3. The Following User Says Thank You to natie123 For This Useful Post:
    PJs (May 13, 2018)
  4. #23
    Dec 2015
    Reading, Berks, UK
    Philip Davies's Tools
    That is a very nice looking appliance. I’m curious to know why you took so much material off when topping the teeth. When a saw has been badly sharpened, I charge more if I have to do more than 6 strokes, because then the teeth have to be evened out. One tooth will need several strokes, the next less.. You didn’t do that in your example. I top only to the lowest tooth so that there is a flat on each tooth, then file until the flat just disappears. If a saw has never been resharpened, usually each tooth gets no more than 3 passes. When I’ve done both sides, I peer at each tooth very closely, in case there is a barely visible flat still, which entails bobbing backwards and forwards to catch a minute reflection. Unless I missed something, you did not account for the fleam. I would encourage people to learn to sharpen, after all there are lots going, why buy a new one, save your better saws until you can do a satisfactory job on one that’s had a lifetime’s use,like thisFILER GUIDE FOR HAND-SAWS-image.jpg..This is a quality Disston, which I have done 3 times. But you must file every other tooth from one side, turn the saw round, and then do the others, remembering the angle, the fleam, is “mirrored”, as you would cut a pair of mitres. I usually file from handle to toe, as you did, which is wrong, I believe, but it helps to remember that the direction of the file stroke is towards the toe, from each side. The previous owner of this Disston didn’t know that, so he can never have been satisfied with his sharpening and would have tended to cut in a circle. I bought a file guide when I started, a plastic thing, one file fits all, mucked up my first saws, but it did indicate the fleam.
