Results 1 to 4 of 4
Thread: Fender dent pulling - GIF
    durrelltn (Aug 28, 2022), mccwho (Sep 1, 2022), nova_robotics (Aug 26, 2022)
    Sep 2018
    nova_robotics's Tools
    Use hot glue. Seriously. Professional paintless dent repair shops do this. They either hot glue a small semi-disposable insert to the dent, or they just heat up the end of an entire stick of hot glue. You stick that to the dent, then you pull it off. It works amazingly well. I've fixed probably a dozen dents doing this. The hot glue stick will generally pop off, but you just heat it up and do it again. Do it a dozen or so times and you can massage a dent out without ruining the paint. Then a little splash of rubbing alcohol and the hot glue wipes right off without leaving a mark.
    I've also repaired dents by grinding, welding studs, then using a slide hammer. But holy moly does that take a ton of work. And it never looks perfect afterwards. The paint is never 100% when you're done.
    Anyway, hot glue. I'm really not joking.
    Edit: I bought this exact tool off Amazon a while back. Works great.
  4. The Following 2 Users Say Thank You to nova_robotics For This Useful Post:
    durrelltn (Aug 28, 2022), mdhatter3 (Aug 26, 2022)
    Apr 2016
    Buffalo, NY
    He’s right. I have dents in my ‘87 Trans Am and my ‘02 Firehawk removed this way and with the pry bar and plastic mallet. Absolutely no marks or paint damage.
    As long as the dent does not include a sharp crease and the paint is undamaged then a huge amount of body work can be done without the need to grind away the paint and weld the studs in place, even some creases can be ironed out using thumping paddles from behind or dollies and a urethane hammer. Dry ice is great for many of the hail dents as well
