Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: Fence for portable table saw
    Oct 2016
    I agree, look at how it is attached, then look at ways to either add a sacrificial fence or either build a new one or buy a new one.
    There are tons of ideas on the web for DIY table saw fences and depending on how often you are going to use it, along with what you will use it for, a DIY fence maybe the way to go. If you think you will be using it a LOT and for big projects, then I would be looking at buying a new Table Saw.
    There are Table Fence Clamps that are designed for DIY fences, you simply drill two holes in the top of the fence and clamp them to your existing fence. This way the clamps don't get in the way when cutting wood. This way you can have any length you want.
    These are the clamps
    Miter Gauges & Clamps - Fence Clamp
    A very good source for almost anything is Pinterest. Take a look here for some DIY Fence Ideas
    https://au.pinterest.com/search/pins...yped&term_meta[]=tablesaw%7Ctyped&term_meta[]=fence%7Ctyped
    Hope this helps
  2. #12
    Glendale, California
    tony_912's Tools
    Quote Originally Posted by petej View Post
    Hello...as the title says, I hope I'm in the right place for this question. I have a contractors portable table saw (which is all I can afford at this time) and I don't like the fence on it. It's only about an inch wide and accuracy is not it's strong point!! I was wondering if I made it wider with a layer of 5/8" ply on both sides and glue on a layer of 1/4" luan over top of the ply, would that get me more stability or am I just going to mess up my existing fence and be SOL?
    No need for gluing. Some of the fences have holes that are designed just for screwing plywood fence. You can use half of the holes for one side and another half for opposite. You will need corresponding holes for the screws. In any case you cannot make it worst.
    Dec 2016
    Ralphxyz's Tools
    Throw a couple of C-clamps on it and clamp it down, you could also put a 3/4" plywood on the back side to stiffen it up.
  4. #14
    table saw fence
    as per your description the standard fence on these saws are more for quick cuts and not for fine accuracy, would advise you put a peace of melamine on the side where you do your cutting to make the surffuce have less friction and tighten it through your old fence with machine screws. counter sink the screw heads in the melamine, i did it a while ago with an old saw and works fine
    16mm or 5/8" melamine is very sturdy for this application
  5. #15
    Although I haven't implemented the project the embedded YouTube video gives the most direct answer to your question:
    "How To" Turn a Crappy Table Saw into a Good One - create a new surface and fence that moves under more control
    Regards, Klaus
  6. #16
    Aug 2016
    Lots of good comments here, Pete, but they all boil down to this:
    How does the existing fence clamp to the table? What mechanism is there to adjust the fence to make (and keep) it parallel to the saw blade?
    I started out with an old Craftsman contractor's saw. That fence clamped very securely to the table, so I was good there. If your saw's fence clamps securely so it won't move, then you're halfway there. If not, it gets harder with the simplest solution the "clamp a fence to the table" solution mentioned above, or otherwise cobble together a better clamping mechanism for the fence.
    My problem on that old Craftsman was that the fence was not square to the table, and not square to the blade. I built a long box out of baltic birch plywood that fit over the original fence, rested directly on the table, pivoted at a point roughly in line with the front of the blade, and had a micro-adjust screw at the "nose" on the far end. Because the box was carefully constructed and rested directly on the table, it was always square to the table. After clamping the fence so as to be the proper distance from the blade, I could check the fence for parallel by measuring from the miter slots to the fence, and adjusting as necessary to ensure the fence is parallel. If your miter slots aren't parallel to the blade, then you really need to adjust that as well.
  7. #17
    Sep 2016
    Hi Petej
    I had the same problem with a old saw, I found this one and it works great.
    Homemade table saw fence
    Have fun
    Pappyjer
  8. #18
    Supporting Member pfredX1's Avatar
    Sep 2016
    Delaware
    pfredX1's Tools
    You almost described a fence I made for one of my table saws. Except I used s 2x2 piece of square tubing.
    https://www.instructables.com/id/Hom...p-Fence-Build/
