Results 1 to 9 of 9
Thread: Faster Cutting of Square Tubing On a Horizontal Bandsaw
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    This video presents a way to speed up the cutting of square tubing on a horizontal bandsaw. The trick is to use V blocks:
    Rick
  2. The Following 3 Users Say Thank You to rgsparber For This Useful Post:
    Altair (Dec 28, 2014), jere (Feb 13, 2015), kbalch (Dec 18, 2014)
    Very informative, Rick! Thanks for showing this.
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Rick,
    I will definitely try this technique the next time I cut any square or rectangular tubing. I wonder if substituting homemade hardwood "vee" blocks instead of precision vee blocks would work almost as well? I like your other video using a wood form to help in cutting thin wall angle stock. Thanks for sharing, Paul
    Nice tip. Thanks for sharing Rick.
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Rick! I've added your Square Tubing Cutting Method to our Bandsaws category, as well as to your builder page: Rick Sparber's Homemade Tools. Your receipt:
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    Hi Rick , I just don't cut thin tubing on my bandsaw it jumps the blade every time. but I like your idea...:O)
    the reason is that I use the blade until there aren't any teeth left and it is stretched soooo much it likes to come off the pulleys.
  8. #7
    Supporting Member jere's Avatar
    Feb 2015
    jere's Tools
    Not sure what blades you are using but you might want to try USA made bimetal blades. They make a huge difference and they can be bought from harbor freight for $30 or so. I use those and some pipe threading/cutting fluid. My bs eats tubing up,with all teeth intact.
  9. #8
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    I use Starrett bi-metal blades. As you say, they work great.
  10. #9
    Feb 2013
    South of Brazil.
    Hotz's Tools
    Excellent tip, thanks sharing your tool.
    H ...
    Sorry my mistakes in english.
