I made a Spindle Nut Wrench to remove
the spindle nut.
The ring is a piece if DOM, that’s
Drawn over Mandrel.
I cut it off a bigger piece I had, milled flat, since I don’t have a working lathe at the moment, drilled two holes the right size for the pin holes in the nut, then pressed in a gage pin that I cut in half with a die grinder, they aren’t that expensive”, then I bolted on a piece of 3/4 rod stock that I milled two flats on after I drilled and tapped two holes. It actually has to be bolted on after the ring is slipped over the spindle.
