Results 1 to 6 of 6
Thread: External combustion engine - GIF
    External combustion engine.
    NHRA Funny Car engine explosion
    Engine explodes on dyno - GIF and video
    NHRA engine teardown and reassembly - GIF
  2. The Following 7 Users Say Thank You to Jon For This Useful Post:
    baja (Jul 25, 2019), Miloslav (Jul 27, 2019), Rangi (Jul 24, 2019), Scotsman Hosie (Jul 26, 2019), Seedtick (Jul 24, 2019), Toolmaker51 (Jul 25, 2019), Tule (Jul 25, 2019)
    Supporting Member Radioman's Avatar
    Jun 2018
    Massachusetts
    Radioman's Tools
    That is an extremely heavy duty connecting rod. I bet when asked the operator said he was not abusing the engine at the time. I can’t even imagine the force necessary to do that to such a well-crafted component.
    Marion, Iowa
    metric_taper's Tools
    Seeing how much burned oil was on the connecting rod main bearing journal surface, it does appear this made much knocking noise before failure.
    Dec 2017
    NeiljohnUK's Tools
    Vorsprung Durch Technik, as driven by yet A(nother) U(n) D(oubted) I(diot) probably. Following the VW/Audi's emissions scandal, and a number of other German vehicle failures Merc road springs snapping due to corrosion after 5 years, BMW's killer front fork failures and AUDI TT's propensity to crash following rear suspension/wheel bearing failure, it's time to realise German high qwality no longer exists... Engineering by accountants has finally killed it off, if it ever really existed in the first place.
    hemmjo's Tools
    The way I see it, at 0:21-0:24 seconds, the bent rod and burned look of the bearing surfaces suggest the rod welded itself to the crank journal. Then the crank continued to turn which bend the rod, the rod then pulled the piston down out of the cylinder where the light weight aluminum piston was ground up by the spinning crank, much like it would be in a hammer mill at the recycling yard.
    Many possible causes for the initial failure; engineering, misuse, etc. As mentioned above, all industries are now plagued by accounts running the engineering and production departments.
    12L14's Avatar
    Aug 2017
    12L14's Tools
    Actual external combustion engine(well, anemic proof of concept)
  8. The Following User Says Thank You to 12L14 For This Useful Post:
