Thread: Expansive Bit Modification
    Supporting Member Improvised DIY's Avatar
    Feb 2022
    Improvised DIY's Tools
  2. The Following User Says Thank You to Improvised DIY For This Useful Post:
    Jon (Oct 12, 2023)
    Thanks Improvised DIY! We've added your Expansive Bit Modification to our Drilling and Drill Presses category,
    as well as to your builder page: Improvised DIY's Homemade Tools. Your receipt:
    Supporting Member Mook's Avatar
    Sep 2023
    Mook's Tools
    A good tip for using hexagonal collet blocks.
    The datums are the flat faces, not the points.
    In this case when milling the 3 flats, the side of the cutter could be used as it is line with the datum face of the block and vice jaw. A bonus is a nice radius where the flat meets the shaft and if six sides are needed then 2 can be machined in one setting.
  5. The Following User Says Thank You to Mook For This Useful Post:
    Improvised DIY (Oct 12, 2023)
