Results 1 to 10 of 15
Thread: Exhaust on a petrol generator
    Post Exhaust on a petrol generator
    Hi..........Iam wanting to put a petrol, electric start, low noise generator in a shed with access to run it from the outside and seal it inside (a shed inside a shed), but with a lid on the inside for access, the generator will be housed in a heavy duty cage, as we have a few tea leaves around.
    Im looking for advice on the following, is it possible to do? and safe?
    1) can the exhaust pipe be extended to take the fumes outside, when inside the workshop/shed via a small fan
    2) put a pipe on the air intake from the outside, via a small fan
    3) how to keep the any noise level down, when inside the workshop/shed
    cheers
  2. The Following User Says Thank You to rlloyd For This Useful Post:
    Seedtick (Nov 3, 2017)
    Supporting Member Al8236's Avatar
    Dec 2014
    Kendall Washington
    Al8236's Tools
    Yes to the first two minus the fan idea an engine is just a pump after all and will move the air and exhaust on its own if you don't restrict the flow!
    As to number three since you are building a box around it just sound insulate the inside of it!
    From the time you're born till' you ride in a hearse, there's nothing so bad it couldn't be worse!
    Dec 2016
    mrehmus2's Tools
    Quote Originally Posted by rlloyd View Post
    cheers
    You do have to allow some air flow to cool the engine. Even water-cooled engines sometimes overheat if they don't have a bit of air blowing over the oil pan, etc. Don't know what you mean by a cage but even the generator requires cooling or it will have a short life at best.
    Supporting Member myavid76's Avatar
    myavid76's Tools
    cheers
    I would recommend that you put your small shed with the generator in it outside your big shed for safety concerns. A small exhaust leak in a small enclosed area like a shed can be deadly. But to answer your question, no fans needed. make sure the exhaust is piped with rigged threaded pipe and use sealant on the threads and run the pipe at least one foot past the outside of the shed. make sure the intake pipe is at least twice as large as your intake at the motor and you must have an air filter. Your biggest problem is going to be the heat from the generator itself. Small air cooled motors will overheat quickly in an enclosed environment.
  6. The Following User Says Thank You to myavid76 For This Useful Post:
    Toolmaker51 (Nov 4, 2017)
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    Ditto for myavid76 but I would bury an old drum with at least 27 times the volume of one cylinder a few feet underground sitting on a few inches of gravel. Put a drain in the bottom, feed in exhaust from top with the exit about 1/2 way down inside drum and take an outlet pipe from the side about 1/4 down,(plastic O.K. for pipes & drum once 3' or more from exhaust port),out under ground at least 6 feet and up and out. Make sure you have a U-bend on the outlet to stop rain water and screen it to stop rodents and wasps.
    You can do the same for the intake and with decent sound insulation you will not know it is running.
    I've done two like this for remote camp sites where you can hear a Mossie at 2 miles and it works well. Generators are in concrete block enclosures with sand filling and lids made of 1/2 height blocks sand filled between 3/4" treated plywood with pipe from intake drum to enclosure and then just out about 10' with el cheapo ventalation fans powered directly from generator,(when genset is running so are the fans).
  8. The Following User Says Thank You to NortonDommi For This Useful Post:
    Supporting Member Hans Pearson's Avatar
    Jan 2017
    I have a generator exhausting through a pipe about 50% larger than the original exhaust stub and about 12 ft. long - no problem. Intake as above is fine, just remember that an intake generates a bit of noise as well. The big problem is static heat build-up around the engine if in a relatively sealed room. Good ventilation is essential or you could have the whole lot catching alight on you (generators generate more than electricity, they generate a considerable amount of heat too, especially under load).
  10. #7
    There is one thing to avoid when passing your exhaust pipe through the wall. DO NOT hard fill between the pipe and the wall. If you do it will transmit noise and vibration to the wall.
    When we moved into our house 30 years ago we were off grid and the previous owner had installed a nice Lyster diesel gen-set in the garage below. He cemented the exhaust pipe into the wall. When it was running the furniture upstairs would walk around the room. One of my first jobs was to chisel some clearance around the pipe, furniture remained stationary then. Incidentally my second job was to build a generator house about 20 metres from the house, then we didn't even know when it was running, except that we had power.
    The area under the house where the generator was originally is now my workshop, when installing that I put my heavy vice on a steel post set in a deep block of concrete whilst pouring the concrete floor. At the top I fixed a triangulated bracket bolted through a concrete block wall, and did likewise for a grinder stand. Her indoors knows when I am grinding or hacksawing something in the vice. The vibration is carried right up into the house. It is the most solidly mounted vice that I have had though.
  11. #8
    Quote Originally Posted by Al8236 View Post
    Thanks for the reply
    The box will be 18mm 3x2 18mm with insulation between
    PS I'll go into more detail when answering the other replies
  12. #9
    Quote Originally Posted by mrehmus2 View Post
    The generator will sit inside a heavy duty metal cage. with around 3-4" away from the internal walls of the box which will suround it, access to start the generator will be from outside the shed via a side door, which will left open when its running anyway.
    The fuel tank will be accessable from the inside & the pull start if needed via a hinged lid, and also to remove the generator if need be.
  13. #10
    Quote Originally Posted by myavid76 View Post
    I would put it outside in its own shed, but it will not last two minutes, it has happened not long ago someone thought they had took all the precautions he could, but it still got nicked.
    Thanks for the pipe info. was thinking on the same lines.
    Hopefully answered you question regarding overheating in the last reply, I could put some 12volt fan to help with air circulation inside the box
    cheers
